1 - 4 of 4 Posts
Background: 97 gti vr6,
recently had to pull my glovebox off becuase my latch broke, ever since my airbag light has been going off randomly, however my engine light isn't steadily on, or isn't always on when the engine light is on. my check engine does come on, but rarely (has been ever since i chipped my ECU (autotech)). Do i need to go through my airbag system and check for excessive resistance, and does anyone have any tips for checking the system (besides disconnecting the battery)???
busted ginster 97
Discussion Starter · #2 ·
Re: Airbag Light (semperjim)
also... making a knocking noise on hard corners, have replaced my left wheel bearing twice, my entire right side axle and my left inner cv joint. no signs of wear on any wheel well parts, any ideas?
Clunking noise is probably the rack... i've had the same thing for about 10000 miles now... i'm not too worried about it... when the rack starts leaking then i'll replace it
Well when I put in my new steering wheel,the light stayed on.So I ripped the light out,hence no more airbag light!
1 - 4 of 4 Posts
