I've started to be annoyed by the honk that my 06 Jetta 2.0T makes when it locks, like a lot of ppl who have 06 models. When I originally test drove the Jetta in 2005, it had the nice alarm system that chirps. I've read all the below threads:
http://forums.vwvortex.com/zerothread?id=2332741
http://forums.vwvortex.com/zerothread?id=2279004
http://forums.vwvortex.com/zerothread?id=2288623
I figure that there must be a way to install this special horn to make the car chirp instead of honk. In one of the above threads, Theresias mentioned that some cars had the Byte 16 Bit 4 enabled and some not. Activating this Bit (Siren Installed) with my VAG-COM creates the following error:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 242
Mileage: 8826 km
Time Indication: 0
Date: 2000.00.00
Time: 13:46:31
After doing a search in the VW technical documents on Ebahn.com, it became obvious that this alarm horn H12 is not installed and that would explain why the alarm uses the two horns built in the lower bumper vents (H2 and H7 if I'm not mistaken). I called my VW dealer and was quoted $273CAD for the part (1K0 951 605C). It mounts in the passenger fender well and is connected to the Alarm Horn relay.
Theoretically, if we install this part and activate the Byte 16 Bit 4 in the 46-Comfort convenience and other appropriate bits, we should have a car that chirps, no? I don't think it has anything to do with a different control module version. Has anyone done this installation? I'm waiting for my dealer to tell me if they can install it.
Modified by mattenfeu at 9:40 PM 8-6-2006
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 242
Mileage: 8826 km
Time Indication: 0
Date: 2000.00.00
Time: 13:46:31
