Updated list
VR6 PARTS!!!! & CORRADO PARTS!!!!!!
List updated 7-24-15
HUGE PARTS LIST. READ IT!!!!!!!!
List includes parts from : 1990 g60 obd2vr swapped Corrado & 1992 SLC obd1 vr
!!!READ THE LIST!!!!! READ IT!!!!
TONS OF PICTURES OVER 200 PICTURES OF EVERYTHING ON THE VORTEX ADD, SEE BOTTOM OF LIST FOR LINK.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!IF ITS NOT ON THE LIST I DO NOT HAVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
******ENGINE BAY & DRIVE TRAIN STUFF*****
(This section includes motor parts, and all things under the hood including core supports, reservoirs etc etc)
-List has some obd2 and a few obd1 items ... Look through pics
Vr6 bottom end. From the oil pan to the top of the block -250 OBO
Vr6 12v head, has 2 bent valves but no other damage that I can see. - 50
VR6 CCM 5 speed Trans -350
Vr6 passenger axle -30
Vr6 electric water pump -25
Vr6/ mk3 4 bar fuel pump and sending unit -100
Vr6 stock intake boot -30
Vr6 idle stabilization valve - 50
Vr6 upper rad hose - 50
Vr6 make shift upper rad hose - 20
Vr6 coil box (raid tray obd1) -50
Vr6 stock gray plug wires - 10
Vr6 red NGP plug wires (barley used) -40
Vr6 plastic plug wire guides - 30 for all 3 pieces
Vr6 spectre polished cold air intake with MAF -50
Vr6 (any hydro Clutch) slave cly -50
Hydro line (line from clutch master to slave) -50
Vr6 fuel injectors (6) -40
Vr6 fuel rail -40
Vr6 billet crack pipe -50
Vr6 billet SAI plug - 10
Vr6 alternator -50
Vr6 alternator wiring harness -25
Vr6 aluminum AC PS bracket -20
Vr6 radiator - 100
Vr6 rear engine mount bracket (aluminum) -20
Vr6 oil filter housing -10
Vr6 T stat housing and sensors -20
Vr6 clutch kit - pressure plate, fly wheel , disc. All in great shape -50
Vr6 timing chain cover (aluminum) upper and lower - 30
Vr6 obd2 intake Mani -60
Ce2 fuse block -50
Vr6 obd2 throttle body - 40
Vr6 exhaust manifold -40
Vr6 belt tensioner -5
Vr6 valve cover (aluminum not plastic) -60
Slim fan -50
Vr6 oil cooler with hoses -25
Vr6 shift box with linkage - 50
100mm axle cups for mk2/mk3 transmissions -50 for the set
Vr6 cat back exhaust 2" cat to over the rear beam- 50
AAA racing muffler -40
Leistritz German made muffler -40
Stock vr6 mk3 suspension (looks pretty crappy) definitely good enough for a roller! -50
Corrado fuel lines .... I have all 3, all in good shape - 150
Corrado center rain tray (it's beat to ****, but better than nothing -5
Corrado passenger side rain tray piece -40
Corrado Power steering reservoir - 20
Cruise control pump -40
Upper G60 Rad support -100
Washer fluid jug -20
Wiper motor with linkage -80
Hood prop rod -20
*************BODY STUFF*****************
G60 Hood - 100 (has dent from exploding g-ladder)
Green Hatch (stripped of everything but glass) (green) -100
Red Hatch still has all the wiring/ glass /struts / wiper motor -250 (red)
Hatch middle brake light metal housing -25
Hatch middle break light bulb tray with wiring -25
Hatch struts - 25 each
Hatch lock with key , wiring and vacuum pump - 40
Hatch latch with linkage - 25
Wing -50
G60 front bumper -300 with bumper grill- 250 without
Vr6 or g60 Aftermarket fiberglass corrado bumper (forget brand) -120
SLC/g60 Front bumper rebar -50
Brake lines , both lines front to back -25
Gas cap - 10
Gas fill door -20
Mirror trim (black plastic around door mirrors) -20 each
Hood cable sleeves -50 for both (from handle to engine bay & the section for the rad support) jus the plastic sleeves no cable or handle included
Rear bumper mounts - 10 each
Hood hinges -30 for the set
Power mirror motors with harness -30 each
Inner fender wells -40 for the set
Anti theft siren -20
SLC Horns -40
G60 horns -40:
G60 fender passenger side(black) (had small golf ball dent at a easy to fix spot) -50
SLC passénger fender passenger side (red) clear coat peeling -150
Wind shield Wiper arms -20 each
rear CorrAdo badge -50
G60 grill badge (painted white ) -50
Rear g60 badge -50
G60 driver door & qtr rub strip- 25
G60 pass door & qtr rub strip -25
SLC (thicker than g60) pass door $ qtr rub strip -25
Drivers door seal -50
Passenger door seal -50
Hatch seal -50
G60 door sills the plastic sill that say (corrado) well these don't say Corrado, only vr's say that. There are striped g60 style -30 for the pair
**********INTERIOR STUFF************
!!!!!!!!!!!!ALL TRIM IS BLACK!!!!!!!!!!!!!!!!
Rear view mirror -25
G60 gauge cluster -80
Wiper control /mfa stalk -50
Wing switch -50
Sunroof switch -50
Window switch (driver side ) -30
Fog light switch -30
Rear defrost switch -30
Power mirror switch -30
Cig lighter/ 12v outlet -40
Hvac blower motor -30
HVAC air ducting .... Everything, upper and lower -20
Inside door grab handles -10 each
Dash skeleton -50
B pillars -25 each
Under dash panels (knee bars) -25 for both
Visors -10 each
D side seat track cover -10
P side seat track cover -10
Sunroof motor cover ..... Has broken tabs could be fixed -make offer
E-brake handle -25
Dome lights triggers /door ajar (little buttons in door jam that trigger dome light on) -30 for the set
Black steering clam shell -80
Top half of a clam shell -25
Inner door triangles -20 each
Inner door handle trim -20 each
Seat height handles - 10 each
Tilt steering handles -10
Drivers side vent housing -25
Passenger side vent housing -25
Headliner (sunroof) 100
Anti theft module -50
Dome light -40
Sunroof motor -100
Cruise control module -40
Power window module -60
Anti theft module - 40
Wing relay /speed sensor to raise wing -50
Small spline adapter with spring -60
Rear seat belts (belts and receivers) -40 each
Front lap belts - 40 each
Automatic seat belt track assemblies with motors -50 each
Central locking pump - 20
Steering lock / ignition with key - 40
Hatch trim.... 3 pieces left
Lower - 25
Left side -25
Right side -25
*******WIRING********
G60 Cluster harness -25
Headlight switch harness (switch to fuse block) -50
Power mirror harness -20 each
Rear defrost / fog light dash harness -25
E brake light indicator harness -25
Air conditioning power harness (engine bay to compressor) -25
Hvac blower motor harness -25
Vr6 alternator harness -25
*******LIGHTS********
Headlights (stock g60) - 80 each
Side marker lights (Amber) -50 each
Tail lights -80 for all 4 or -20 each
G60 fog lights -50 each
Tail light light bulb holder trays - 10 each
License plate light bulb tray -50
Turn signal bulb socket -25
Side marker bulb socket -25
Fog bulb socket -25
*******GLASS*************
Drivers side door window -70
Drivers side rear side window (with seal) -120
Drivers side rear window (no seal) -70
Passenger side rear side window (with seal) -120
Hatch window -100 (comes with free hatch) FREE WOW!!
********** SUSPENSION**********
Complete with calipers, rotors, brakes EVERYTHING! + take the front complete set up, g60 with a vr subframe.
All 4 lug -100 for everything or ask for prices on pieces
G60 rear calipers -15 each
BODY PANELS .... Let me know what you want.... I'll give you a price and cut it out.
I will ship anything anywhere.
Must purchase $25 minimum for me to ship. $25 plus shipping
Listed prices DO NOT include shipping
For personal pick ups I'm 10 minutes from cabela's in hamburg PA 19526
If you need a shipping quote TEXT ME your zip code ..... I will box it, weigh it , measure it and get your quote within a day or two (please do NOT ask for quote if you don't intend on buying, waste of tape and time)
TEXT MESSAGES OR PHONE CALLS IS MY PREFERRED METHOD OF CONTACTING ME.
I WILL REPLY TO EVERY MESSAGE ON EVERY SITE, BUT I WILL REPLY TO TEXT MESSAGES AND CALLS FIRST -484-335-8812
Thanks for you business - Mike Phillips
VORTEX LINK
http://forums.vwvortex.com/showthread.php?t=7175503
Vr6 fuel rail -40
Vr6 alternator -50
Vr6 radiator - 100
Ce2 fuse block -50
Slim fan -50
Hood prop rod -20
Wing -50
Gas cap - 10
Gas fill door -20
SLC Horns -40
G60 horns -40:
Rear g60 badge -50
Hatch seal -50
Wing switch -50
Sunroof switch -50
Dash skeleton -50
B pillars -25 each
Visors -10 each
E-brake handle -25
Dome light -40
Sunroof motor -100
Lower - 25
Left side -25
Right side -25
Fog bulb socket -25
VORTEX LINK
