Just want to give a quick shout out to the customer service at DeAutoLED. I had the original trunk light they recommended for the Alltrack since March of last year and had the flickering issue from the jump. Luckily this thread showed up and I contacted them. They made right the issue; or are in the process of doing so rather. The communication was quick and it was much appreciated. Thanks
Yes - it was honestly the first time we heard of this due to the limited times people do this (turn on all lights in the car manually without car door open or unlocking your door).
So if people are not going to turn on all their lights manually the complete housing is fine.
The complete housing works fine while:
driving (won't flicker)
when you unlock your doors and it opens all lights
or when you open your car door opening all lights
The only issue is when you manually turn on all lights with the TRUNK Housing (stage 3 is fine).
For example: if you open your car door to activate all your lights the Complete Trunk housing will not flicker. If you use the button inside to turn on all lights it will flicker. This is a unique situation. Not many will need all lights on inside or turn them on manually. If anything most will use their domes/suns or simply open the door. We hope this clears up any confusion because we only had this report once from 1 person and we feel the reason is due to not many using the lights in this manner. We quickly made it clear in our listing for anyone interested in using the complete housing without turning on all lights manually.
Thank you
