Re: Alternator belt help....really quick (Pedmaster)
Tighten it more and replace your belts. Don't forget the "hidden" ps pump bolt
i'd say its more of a pita job then a hard job. Not much room to work in there.
Oh yea you might try thread lock if the bolt is coming loose or put on on of the adjuster arms with the splines with the splined nut on the bolt. You know the normal G/J one.
[Modified by pastpargolf, 4:53 PM 2-7-2002]
