'91 Jetta GL (German car, if that makes a difference)
It's got cruise control...what I assume to be a factory option as it's on the turn signal stock and not a separate switching unit drilled into the side of the steering column garnish.
It doesn't work... The diaphragm holds air (I sucked on it's vacuum line and it maintains pressure). The vacuum line looks like it was replaced no more than a year and a half ago and runs all the way to the firewall where it's attached to a little black round thing wit a set of plastic nipples on it. This unit is under the (round) coolant reservoir. The vacuum line from the diaphragm is connected to the nipple on the left, towards the motor. The nipple on the right has NOTHING connected to it.
The idle is crappy and surges about 100rpm when warm.
Is there anything that's supposed to be connected to the nipple on the right? Should it be capped off?
Pedal assembly: The vacuum line(s) I found were firmly attached to their nipples.
I will take a pic of the vacant nipple and the unit itself if need be. Just let me know. I'll be up 'till 4am EST
