An interesting site
580 Views 6 Replies 6 Participants Last post by  vwmann1
A guy, code name "old school, posted this site on the A1 forum, and I asked to borrow it:
http://platinumeuroparts.safeshopper.com/
for those who have time, maybe we can see what they REALLY have in stock. If they even have half of the stuff, we found a new goldmine!
LP
1 - 7 of 7 Posts
Re: An interesting site (92foxrox)
check this stuff out!
13. Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 280mm (11 inch)
Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 280mm (11 inch) Vented Brake Conver: Highly modified cars will benefit greatly from this ultimate brake
URL: http://platinumeuroparts.safeshopper.com/158/349.htm?958
16. SportTuned Clutch Systems VW Fox, 210mm Stock 5 - Volkswagen Parts / Air and H20
SportTuned Clutch Systems VW Fox, 210mm Stock 5: Platinum Europarts offers complete clutch packages (from Autotech) for your watercooled VW that will Volkswagen parts &
URL: http://platinumeuroparts.safeshopper.com/221/214.htm?958
17. Bilstein Heavy Duty GP Shocks (A1 Chassis) Front Fox INDIV. - Volkswagen Parts /
: : : : : Bilstein Heavy Duty GP Shocks (A1 Chassis) Front Fox INDIV. Product Details Stock #: 10.500.P300014 Price: $ 119.20 Qty:
URL: http://platinumeuroparts.safeshopper.com/240/507.htm?958
18. Gauge Panels (3-Hole Panel) Fox - Volkswagen Parts / Air and H20
: : : : Gauge Panels (3-Hole Panel) Fox Product Details Stock #: 10.864.103 Price: $ 24.95 Qty:
URL: http://platinumeuroparts.safeshopper.com/234/1227.htm?958
22. Illumina 5 pt. Externally Adj. Shocks INDIV. (Front Fox) Autotech Conversion - V
: : : : : Illumina 5 pt. Externally Adj. Shocks INDIV. (Front Fox) Autotech Conversion Product Details Stock #: 10.500.BZ1095K Price: $ 165.95 Qty:
URL: http://platinumeuroparts.safeshopper.com/245/569.htm?958
23. Illumina 5 pt. Externally Adj. Shocks INDIV. (Rear Fox) Autotech Conversion - Vo
: : : : : Illumina 5 pt. Externally Adj. Shocks INDIV. (Rear Fox) Autotech Conversion Product Details Stock #: 10.500.BU2770K Price: $ 149.95 Qty:
URL: http://platinumeuroparts.safeshopper.com/245/570.htm?958
24. Clutch Components 210mm VW Fox Pressure Plate - Volkswagen Parts / Air and H20
: : : Clutch Components 210mm VW Fox Pressure Plate Product Details Stock #: 10.341.1248 Price: $ 49.95 Qty:
URL: http://platinumeuroparts.safeshopper.com/220/235.htm?958
25. Clutch Alignment Tool, Fox - Volkswagen Parts / Air and H20
: : : Clutch Alignment Tool, Fox Product Details Stock #: 10.012.343 Price: $ 7.50 Qty:
URL: http://platinumeuroparts.safeshopper.com/219/253.htm?958
1. Solid Rear Swaybars (Fox Sedan and Wagon) 25mm Kit - Volkswagen Parts / Air and
Solid Rear Swaybars (Fox Sedan and Wagon) 25mm Kit: Platinum Europarts offers a rear swaybar design for the Fox that is quite unique. The entire swaybar Volkswagen parts &
URL: http://platinumeuroparts.safeshopper.com/207/467.htm?958
2. Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 239mm (9.4inch)
Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 239mm (9.4inch) Vented Brake Conver: Kit for cars up to mid-1980 with small ATE or Girling calipers. Also for all
URL: http://platinumeuroparts.safeshopper.com/158/347.htm?958
3. Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 256mm (10.1 inc
Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 256mm (10.1 inch) Vented Brake Conv: This kit upgrades all Rabbit, Scirocco, Jetta 1, and Fox models to the larger
URL: http://platinumeuroparts.safeshopper.com/158/348.htm?958
4. Solid Front Swaybars (Fox Sedan and Wagon) 22mm Kit - Volkswagen Parts / Air and
Solid Front Swaybars (Fox Sedan and Wagon) 22mm Kit: Platinum Europarts offers Autotech's front anti-roll bar kit for the Fox designed to locate in the s Volkswagen parts &
URL: http://platinumeuroparts.safeshopper.com/207/460.htm?958
5. SportTuned Brake Lines (stainless steel) Fox Sedan 1987-93 (4pcs) - Volkswagen P
SportTuned Brake Lines (stainless steel) Fox Sedan 1987-93 (4pcs): Every time you brake, some of the mechanical energy put into the pedal is wasted expanding the stock Volkswagen
URL: http://platinumeuroparts.safeshopper.com/159/389.htm?958
6. SportTuned Brake Lines (stainless steel) Fox Wagon 1987-90 (4pcs) - Volkswagen P
SportTuned Brake Lines (stainless steel) Fox Wagon 1987-90 (4pcs): Every time you brake, some of the mechanical energy put into the pedal is wasted expanding the stock Volkswagen
URL: http://platinumeuroparts.safeshopper.com/159/390.htm?958
7. Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 239mm (9.4') Ve
Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 239mm (9.4') Vented Rotors & Pads: Converts all cars from mid-1980 to 1984 to vented rotors. No caliper change is
URL: http://platinumeuroparts.safeshopper.com/158/346.htm?958
8. Rober Bentley Repair Manual (Fox 1987-93) - Volkswagen Parts / Air and H20
Rober Bentley Repair Manual (Fox 1987-93): Platinum Europarts offers the most current factory authorized manuals for your car. These Robert Ben Volkswagen parts & accessories
URL: http://platinumeuroparts.safeshopper.com/153/4015.htm?958
9. Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 239mm (9.4') Ve
Front Brake Conversions A1 Chassis (Rabbit/Scirocco/Jetta 1/Fox) 239mm (9.4') Vented Rotors & Pads: Converts all 1984 1/2 (1/84 prod) and later cars with solid front rotors to
URL: http://platinumeuroparts.safeshopper.com/158/345.htm?958
10. Cold Start Valve (Fox w/CIS-E 1987-89) - Volkswagen Parts / Air and H20
Cold Start Valve (Fox w/CIS-E 1987-89): NO LONGER AVAILABLE. Volkswagen parts & accessories galore! On-line Air/Water Cooled catalogue up to 70% off dealer prices.
URL: http://platinumeuroparts.safeshopper.com/1874/861.htm?958
See less See more
Holy hell where has this place been! Its huge, they've got more parts on one site then i've seen on all the sites before. Mad Crazy Cool
Re: An interesting site (FoxWagonGuy)
are there no pics of this stuff? I like to see what I would pay for
See less See more
Has anyone confirmed that they have the parts in stock?
I tried to order Autotech's 10.1" brake conversion for almost a year. Everytime I called, I was told, "We won't have the parts for 6 months."
See less See more
Re: An interesting site (kennyg)
Hmmm that might pose a problem to this site. It can show it has all the parts in the world, but if it doesnt have them in stock it aint nuthin.
i have had very bad luck with autotech, they told me they would have a set of 83mm pistons in 6 weeks when i called back they told me they couldn't get them. called randy from techtonics and he got them for me.
1 - 7 of 7 Posts
