1 - 8 of 8 Posts
Need a lil help here. I've noticed that these hoses are rubbing together a little bit, and I'm concerned that they will wear through given enough time. Has anyone else encountered this problem, and what did you do to remedy it?? Thank you!
Re: An issue with my Samcos. PICS inside! (cabzilla)
quote:[HR][/HR]Mine touch but dont look worn.
P.S. Zat orange?[HR][/HR]​
Lol no not orange, they're red. Quick digi-cam snap at nite
Re: An issue with my Samcos. PICS inside! (germanrox)
Are they both going to the block? That close to the block and touching, I dont see them moving much. You should be allright.
[walking out to the car to check hoses]
the main central one - nothing you can do, but the one to the right I believe goes to the AUX water pump right? In that case, you might be able to shorten the hose a little and clamp it all back together?
jules
Discussion Starter · #6 ·
Re: An issue with my Samcos. PICS inside! (jcorallo)
Correct the one on the right goes to the AUX water pump. I may try turning the pump a bit to reposition the hose, or possibly just score it and cut to shorten it up a bit.
Discussion Starter · #8 ·
Re: An issue with my Samcos. PICS inside! (Jim Chu)
quote:[HR][/HR]Cold motor, loosen clamps, break the seal on the hose and rotate it so it doesn't touch.[HR][/HR]​
Roger that. Thanks for the tip http://****************.com/smile/emthup.gif
1 - 8 of 8 Posts
