1 - 20 of 87 Posts
You know the story...
Didn't see the dip, oil pan suffered as a result....
So the question is...
Should I get a steel reinforced oil pan or an aluminum one with a skid plate?
I searched and the steel one I found doesn't have a hole for the oil level sensor but it is only like $10 more than the original aluminum one. But, the aluminum one + a skidplate would run me around $400 because the skid plate is $300
So is it worth the money to get the aluminum one (with a hole for the sensor) with a skidplate or should I just get the steel reinforced one?
Also, are there reinforced ones that have the sensor hole, because I would much rather get that, especially if it's cheaper than the skidplate option....
OK Thanx for your time...
Discussion Starter · #4 ·
thanx for the idea, I checked it out but does it have a hole for the oil sensor??? it doesn't say...
nother pic...
Re: (Nevaeh_Speed)
get a skidplate for sure. i busted my oilpan about a year ago and after replacing it i just bit the bullet and bought a dieselgeek skidplate. i cannot tell you how much weight it has taken off my shoulders and how it has saved my ass many many times.
Re: (They_Call_Me_Bob)
been there bro ( http://i126.photobucket.com/al...48301 ).. look into the hybrid, everyone told me about it after i got a new one. but i ended up getting a diesal geek skidplate (put it on in a freakin rain storm last night.. big ups to dave *esoteric vue for laying in a stream of road water to get that effing thing on)... but anyway, i def feel better about driving around now with it on.
invest in it, regardless of what oilpan you get.
dont forget, vw's are lower then most north american cars anyway haha.
i got those steel ramps for oil changes, the normal deisng works well with my van, but the jetta cant go onto them w/o ramps. so i bought "extensions" for cars that are "lower" and the jetta STILL cant get on them w/o breaking the bumper. so i just mounted the ramps differently untill it worked.
Re: Another Oil Pan Destroyed.... (fastgermancar)
What's it like doing an oil change with a skid plate? Sure they cut a hole for the oil pan drain, but you'd still have to remove the skid plate to get to the oil filter...
Re: Another Oil Pan Destroyed.... (bootymac)
Quote, originally posted by bootymac »
you cut a hole for the filter too.
1 - 20 of 87 Posts
