1 - 20 of 59 Posts
I picked this trick up in the Scirocco forums. It serves the same purpose as adding a bead of 3M Window Weld Urethane to the underside of the strut mount to keep the rubber from collapsing, a known problem with "all" aftermarket mounts.
Look here:
https://forums.vwvortex.com/showthread.php?7541657-34-years-ago-to-the-day-January-9-1982/page4
Basically a high quality exhaust hanger for Opels, available here:
https://www.ebay.com/itm/Goma-de-Es...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649 Edit 07/28/2020, the link is dead, try this instead: https://www.ebay.com/itm/Goma-de-Es...527617?hash=item59272fb641:g:ZV0AAOSwQYZWxHTJ
Adavantages:
1) Dirt cheap, I bought enough for 5 cars from Europe for half the cost of one tube of Urethane.
2) No waste. The rest of the tube of urethane is wasted unless you have the energy to do all of your cars in one day (I do not)
3) No curing time, the parts are immediately and fully serviceable.
4) The gap stays super tight, better than Urethane.
I don't know if other hangers from the US would work, but the ones in the link fit perfectly (albeit hard to get in), and road impacts will seat them better and better over time.
What are the symptoms of a failed strut mount? Is it just clunking over bumps? I haven’t noticed that but the other day I was lifting my car on a two post lift with the hood up and saw the rubber portion that sticks through the center seemed to get shorter as load was removed (car being raised) and taller when it was lowered back down.
I didn’t measure but I would guess that it looked as though they changed by a little less than a centimeter. Is this normal or are my mounts bad?
Clunking and the mount moving while raising on the lift. There will always be some movement, but only a very small amount.
78rabbit1.5LGP & 82rabbitpickup1.6DGC
from the top it appears as a giant gap between the top of the strut and the mount
normally bulging out of the black part of the mount
internally the rubber isnt doing anything since its all seperated from the bearing cup to the mount
clunky or wierd handling behaviors or difficulty turning?
simple good fix adding a thick o-ring below
the urethane method is costly at $25 a tube and messy and a time waster for 2 weeks curing time
i wish i knew about this last time i changed my mounts
Discussion Starter · #7 ·
Clunking...
Clunking may or may not occur depending on the fit and condition of the mount's bearing and its associated steel bushing. The main thing you will notice is a 3/8" gap that appears between the mount's upper steel plate and the rubber donut beneath it as you lower the car off jacks.
The main design flaw in the mount is that the rubber has insufficient material to handle the compressive loads of the car's weight and fails even on some 0-mile mounts. Thereafter, the upper suspension perch is essentially resting against the steel of the strut tower.
This might not be a problem for a car at stock height because the abundant suspension travel and the rubber bump stops will provide some margin of protection to the strut tower. But for even mildly lowered cars, moderate road bumps are enough to break the bump stops, at which point the upper portion of the strut tube can hit the shock tower full force and cause the shock tower to "dome" or crack away from the inner fender well steel. The first sign of structural unibody failure will be cracked seam sealer there.
If you have a Mk1 Scirocco, it's also only a matter of time till you get inside-out dents on the hood.
It appears that no new mount will reliably hold up long term, so IMO this mod is essential on all mounts moving forward. I'm in the process of doing this to all 5 of our Mk1 cars :)( or :), I can't tell which).
Discussion Starter · #9 ·
I don't have strut mounts!
Well, you must have something there ;)
That does make me wonder about those camber plates some race cars use. I assume they're not really designed for pothole duty, is some protection somehow built in?
On mine the bearing is encased in polyurethane. I wonder now whether that provides enough cushion to protect the shock tower. It’s awfully harsh
I bought 6 of the CRP, hangers. The order was drop shipped from the warehouse, and I’m guessing only 2 are CRP. All part numbers match, but there isn’t anything that would elude to manufacturer. The other 4 are light gray, and a bit softer....not sure if this would be beneficial.
Honestly, I only bought them out of curiosity and because they were cheap. I run the early mounts, with Fox bushings. I was curious to see if they could be slipped into them. I didn’t even try...
-Todd
Discussion Starter · #13 ·
I've now done the mod to all five of our A1 cars, here are my initial impressions:
On the GTI and the S1, which are "important" cars, I got new mounts and the rubber ring inserts into the gap with some muscle, but no special skills. Hold the mount upside down in a vice, push one side of the rubber in with a thick screwdriver, pry the other side over the steel lip with the screwdriver, and push the rest of the rubber in. I got mine from the European source in the link and they are are hard, but stretch a lot with no tearing. The weight of the car produces zero gap where we often see it :thumbup:. We'll see how it holds up.
On the one S16V I hadn't urethaned and the Cabby, which are "unimportant", I kept the old collapsed mounts and inserted the rubber. I had to make a squeezing tool to open the lower gap enough but the procedure was otherwise the same. With the cars' weight on the mounts the gap is reduced from 3/8"+ to about 1/8", same result I got with urethane but instant and cheap. I'll see how it holds up.
Does anyone have the ID/OD of ones they have successfully put on a mount?
I added a few of the Mercedes cross reference (P/N: 1134920082) to an existing order and they seem too small.
Discussion Starter · #15 ·
45mm x 69mm x 14mm listed over in one of the Scirocco threads, that's the Opel one listed, hopefully the Mercedes one is the same piece.
It's quite small, and frankly when I first looked at one, I thought there was no way I could even start it into the gap, let alone stretch the rest of it over the steel plate.
But it does fit (it helps to grunt and swear as needed), and boy does it work :thumbup:
I am tempted to try this but at the same time a tube of windshield urethane can be had for around $10-15. Considering how fast many of the modern windshield urethanes set (due to customer impatience and installer malpractice), I have not decided what method to try. It will be interesting to see how this new method holds up.
Discussion Starter · #17 ·
From Wiki:
Adopter category definition:
Innovators: Innovators are willing to take risks, have the highest social status, have financial liquidity, are social and have closest contact to scientific sources and interaction with other innovators. Their risk tolerance allows them to adopt technologies that may ultimately fail. Financial resources help absorb these failures.[41]
Early adopters: These individuals have the highest degree of opinion leadership among the adopter categories. Early adopters have a higher social status, financial liquidity, advanced education and are more socially forward than late adopters. They are more discreet in adoption choices than innovators. They use judicious choice of adoption to help them maintain a central communication position.[42]
Early Majority: They adopt an innovation after a varying degree of time that is significantly longer than the innovators and early adopters. Early Majority have above average social status, contact with early adopters and seldom hold positions of opinion leadership in a system (Rogers 1962, p. 283)
Late Majority: They adopt an innovation after the average participant. These individuals approach an innovation with a high degree of skepticism and after the majority of society has adopted the innovation. Late Majority are typically skeptical about an innovation, have below average social status, little financial liquidity, in contact with others in late majority and early majority and little opinion leadership.
Laggards: They are the last to adopt an innovation. Unlike some of the previous categories, individuals in this category show little to no opinion leadership. These individuals typically have an aversion to change-agents. Laggards typically tend to be focused on "traditions", lowest social status, lowest financial liquidity, oldest among adopters, and in contact with only family and close friends.
The last categories are not flattering but I still use a flip phone and I'm OK with it :p.
In this case, I already have a tube of urethane and I'll keep it for something else. I haven't ruled out using two donuts per mount, especially if I'm modifying a mount that has already failed, but in the Scirocco forum there's favorable long-term follow up even with track use. The urethane, no matter how fast it cures, cannot have the weight of the car on it without some significant delay.
Thanks - I'll have to measure the ones I received as soon as I can get back to the vehicle. At first glance I to was thinking :screwy:
As some know, I have tried to install the Continental made mounts and they are much too firm and broke while installing them [in Febi mounts]. Silicone grease is my go to lube for rubber/plastic and all my butcher tricks did not work. Since they broke, I just shoved them in anyway. I seriously doubt if they will work their way out. I installed them in my POS VW pickup with Koni yellows and Autotech lowered springs [bump stops trimmed], we shall see what happens long term. I put around 20k a year on it so it gets a work out.
The dimensions seem to be correct with the Continental's, it just seems the durometer of the rubber is a bit more firm. Since I have not compared with other manufacturers, I'm just guessing.
Oh,I am so in for this, as I need to replace my strut mounts this Spring, as I just got new Koni Yellow inserts to replace my over decade old set.
1 - 20 of 59 Posts
