1 - 19 of 19 Posts
Re: Any GTI owners re-wire their sun roof controls to front dash? (feeling_sinister)
quote:[HR][/HR]Uhh, one question, WHY???
control box is busted, also thought it'd be a cool mod.[HR][/HR]​
Does sound interesting, shouldn't be to hard either, if I'm not mistaken it's just a 3 stage toggle switch. Could probally be done quite easily. Check connections see what does what, then rerun the wiring down the A-Pillar straight to the console. I'm assuming you would put this by the defrost switch?
*edit...if you had the knowhow, you might want to wire it in such a fashon so you hit the switch and don't have to hold it to open/close.
*editedit...I'd think this could be done with a thermal switching device, but I'm not too sure at what rating
[Modified by Pagano, 10:04 PM 2-10-2002]
[Modified by Pagano, 10:05 PM 2-10-2002]
Re: Any GTI owners re-wire their sun roof controls to front dash? (Pagano)
Does sound interesting, shouldn't be to hard either, if I'm not mistaken it's just a 3 stage toggle switch. Could probally be done quite easily. Check connections see what does what, then rerun the wiring down the A-Pillar straight to the console. I'm assuming you would put this by the defrost switch?[HR][/HR]​
Yep. Right by the defog switch. JettaFlite tells me I can use the Jetta window control...
How exactly would the window control be used. I'm actually liking this idea the more I think about it. However I want to do it with the OEM switch, though I do not know how to get it onto a locked toggle so it doesnt spring back out, I'd like to get a hold of a second switch so I could take it apart and look into a thermal switching device to run inline with the power supply
[Modified by Pagano, 10:09 PM 2-10-2002]
Discussion Starter · #8 ·
Re: Any GTI owners re-wire their sun roof controls to front dash? (Zwoobah)
quote:[HR][/HR]How does the switch for the power top in the cabrio work? Same idea, but different[HR][/HR]​
Good call. Hmm...
(NOTE: i never did this mod, im only saying it LOOKS like its possible)
i suggested teh rear window switch/cluster form a four door A3 because there are two seprate switches (one for drivers rear, on for passengers rear). one switch could be wired up to operate the sunroof sliding forward and back, the other could be wired to operate teh tilt. the rear window control cut-off switch (located between the two swtcihes in the cluster) could possibly be used for some other auxiliary device...maybe foglights or something. who knows...?
Your post got me thinking....
Just a disclaimer: I know nothing about electronics/switches
Would it be possible to somehow make my sunroof work like my windows (1-touch open) so I don't have to hold the switch to make it open all the way?
It would be great if I could do this without modifying the current (stock) control. If there were a way to do this, I'm sure A LOT of vortexers would be interested in doing it.
Any wiring experts on here? If it would work, I think it would be really cool...
ROB
Re: Any GTI owners re-wire their sun roof controls to front dash? (JetTAFLiTe)
i dont know if its the switch itself, or if its the alarm control/brain...but on the 98-99.5 models, the windows have one touch up AND down. that could possibly give teh sunroof a "one-touch" open/close feature.
so maybe somehow modifying a window switch to work on the sunroof? Let's keep this thread alive, I bet it could be done and would be really nice!
ROB
· Banned
Re: Any GTI owners re-wire their sun roof controls to front dash? (VReihenmotor6)
quote:[HR][/HR]cost me like $7 to make the sunroof open with one push[HR][/HR]​
Sounds like a Time delay relay to me. http://****************.com/smile/emthup.gif
hey how about this idea
get another defroster button
take it apart and mod it so it is only momentary contact
while it is apart carefully mask the heat lines so only the rectangle shows
wire this to the pulse timer relay for the opening of the sunroof
just a thought
but it might be worth it and would deff look oem
which is my style if you haven't guessed by now
I'll post more if I think of any thing else
1 - 19 of 19 Posts
