1 - 9 of 9 Posts
Hi all and Dana :)
Long time reader (2003 registered I believe) and recent poster :)
I hope someone from this forum can point me in the right direction with my MFD issue, having fitted a 9W7 - 7P6 035 730 D bluetooth module to my MY09 Passat R36 recently.
Everything works perfectly, can view phone on the RNS510 with FW2760, can view PHONE screen on the white MFD and even the 'STAR' PTT button works as it should.
The ONLY thing I can't seem to do is operate/control/browse any of the phone menu which displays on my white MFD screen, the "phone" button, "OK" button, "arrow up" button, and the "arrow down" does not seem to communicate in this section, but the buttons work perfectly in every other single MFD menu.
I have a 8 button multifunctions steering wheel as per OEM.
I have spent countless hours in VCDS and reading every forum I could get my hands on, but have had no luck in getting this last detail to work, so any help would be MORE than appreciated.
My Autoscan is as follows:
Thursday,03,November,2011,17:44:36:06980
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 3C0
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 37 42 44 46 47 52
53 55 56 62 65 6C 6D 72 77
VIN: WVWZZZ3CZ9E0XXXXX
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 AM HW: 03H 906 032 AB
Component: R3.6-FSI-EU4 G 3488
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 6DDBC4B00D0A
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1982
Revision: 04844002 Serial number: 00000811130658
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1221B74C74F4
Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 T HW: 3C0 614 109 T
Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786422898
Coding: 0001439
VCID: 2F671EB8C786
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW46.rod
VCID: 7EF9F3FC506C
4 Faults Found:
9470741 - Temperature Sensor for Left Footwell Vent
B1083 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 30765 km
Date: 2028.14.25
Time: 17:27:12
9470997 - Temperature Sensor for Right Footwell Vent
B1084 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 30765 km
Date: 2028.14.25
Time: 17:27:12
9472533 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 30765 km
Date: 2028.14.25
Time: 17:27:12
13636352 - Control Module Not Coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 153
Mileage: 30765 km
Date: 2028.14.25
Time: 17:27:11
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009160333
Coding: E68E8F2700041A00470A00000F000000000B5B435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 336F12C82BAE
Part No: 3C2 955 119 B
Component: Wischer 201108 022 0601
Coding: 00046997
Shop #: WSC 05124
Part No: 1K0 955 559 AH
Component: RLS 080109 054 0402
Coding: 00995565
Shop #: WSC 05124
3 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 199
Mileage: 30887 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 199
Mileage: 30831 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 254
Reset counter: 227
Mileage: 30765 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97540832609382
Coding: 300103
Shop #: WSC 05314 000 00000
VCID: F1E358C09132
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__00S VW10 HI 1815
Revision: 19013000 Serial number: 0039BPR6XEFE
Coding: 0012371
VCID: FAF17FECCC44
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507CN
Coding: 0001412
VCID: 6DDBC4B00D0A
Part No: XXXXXXXXXXX
Component: E0221 002 0030
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 871 S HW: 3C0 920 871 S
Component: KOMBI H04 0107
Serial number: 00000000000000
Coding: 160F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
VCID: 346D11D42EA0
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08C0805DF
Coding: FDA3FF07524612002003
Shop #: WSC 30081 959 59690
VCID: 2A510FACFC64
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 226
Mileage: 31610 km
Time Indication: 0
Date: 2029.14.17
Time: 20:47:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 227
Mileage: 31610 km
Time Indication: 0
Date: 2029.14.17
Time: 21:10:27
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 448D41147E00
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 75EBECD0655A
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 A HW: 5N0 035 342 A
Component: SG EXT.PLAYER H13 0062
Revision: A1001003 Serial number: 7667018628
Coding: 010000
VCID: 254BFC90957A
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F671EB8C786
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
Component: RNS-MID H03 2760
Revision: AB001001 Serial number: VWZ6Z7H8349006
Coding: 04050000010000A100
ASAM Dataset: ------------------------- ------
VCID: 2E5903BCC08C
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 176
Mileage: 31373 km
Time Indication: 0
Date: 2029.14.14
Time: 13:34:19
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000511789001
Coding: 0005047
VCID: 71E3D8C01132
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 144
Reset counter: 227
Mileage: 30765 km
Time Indication: 0
Date: 2028.14.25
Time: 15:25:37
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 143 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5D09B4F690
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 052 0412
Coding: 18900A00D1034E7630009C1D7008DFCE105801
VCID: 75EBECD0655A
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Component: Innenraumueberw.004 0611
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 227
Mileage: 30765 km
Time Indication: 0
Date: 2028.14.25
Time: 15:32:41
00323 - Vehicle Inclination Sensor (G384)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 222
Mileage: 31532 km
Time Indication: 0
Date: 2029.14.16
Time: 17:13:55
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C0 035 456 J HW: 3C0 035 456 J
Component: DSP 10 Kanal 0030
Revision: 00H05001 Serial number: 75815000788504
VCID: 2757F698EF76
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000628689006
Coding: 0005046
VCID: 72E1D7CC1434
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 227
Mileage: 30765 km
Time Indication: 0
Date: 2028.14.25
Time: 15:25:37
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000217511
Coding: 0000057
VCID: 2855F5A4E268
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 2344193
VCID: 346D11D42EA0
Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E5903BCC08C
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 176
Mileage: 31373 km
Time Indication: 0
Date: 2029.14.14
Time: 13:34:19
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000720121
Coding: 0000144
VCID: 70E5DDC41A38
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0453
Coding: 0161211
VCID: 75EBECD0655A
1 Fault Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Mileage: 31350 km
Time Indication: 0
Date: 2029.14.12
Time: 21:13:27
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J8X0107
Coding: 0020007
VCID: DFC72E7877A6
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 F HW: 3C9 827 383 F
Component: J605 HECKDECKEL 0720
Revision: 00H27001
VCID: 346D11D42EA0
Part No: 3C9 827 384 F
Component: J756 HECKDECKEL 0720
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000739037
Coding: 0000144
VCID: 71E3D8C01132
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 D HW: 7P6 035 730 D
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668498228
Coding: 0200000000010110
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW46.rod
VCID: 336F12C82BAE
End ---------------------------------------------------------------------
Some notes regarding this:
- Dealer fitted MDI kit, which I assume is something to do with the AUX-IN open short
- I recently upgraded to the latest Climatronic unit 5K0 907 044 BT, so i'm pretty sure that is the Climatronic errors. Hopefully Dana can help with some guidance on that in a separate thread.
- Recently changed front parking globes to SMD's hence the error
Any help appreciated regarding the bluetooth!
Dino.
You might try coding the WorkShop Code (WSC) in the telephone module (Address 77) from:
to:
Shop #: WSC 12345 123 12345
Here's the code in my 9W7 installed in a 2010 Jetta sedan 2.5 Tip gasser:
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669641860
Coding: 0A00000000010100
Shop #: WSC 02172 444 59389
ASAM Dataset: UHVNA A01009
ROD: UHVNA_VW36.rod
VCID: E2C0200844DF
Thanks Mr TW :)
I will change it and see what happens, fingers crossed!
Are you able to navigate through your phone book on the MFD, via the steering wheel?
Any chance of linking up to a pic online showing which steering wheel you have in your car?
Here's a picture of my MFD+ showing the phonebook selection. It's a bit blurry. Don't be confused by the 0 miles...I took this photo during the installation of a new instrument cluster and the immobilizer had not yet been programmed. And, yes, I can navigate through the phonebook with the buttons on the steering wheel.
I have the following steering wheel from a 2009 CC: 3C8 419 091 AK E74. This version was apparently used on the early production 2009 CC and maybe the early production 2010 Golf models. It looks like this (obviously, the air bag is not on the steering wheel):
Note that the electronic module inside the steering wheel is behind the left spoke buttons, not near the lower spoke. The Clock Spring has a connector that plugs into a socket behind the white part number label at the left spoke.
Here's the coding for the SWCM (Steering Wheel Control Module) (0001831) and the internal steering wheel electronic module (00000227) in my Jetta:
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 054 0110
Coding: 0001831
Shop #: WSC 00056 555 39890
VCID: 76E8EC587857
Part No: 3C8 959 537
Component: E221__MFL-TAP H2ÿ 0021
Coding: 00000227
Shop #: WSC 00000
Very old thread but I hope someone will be able to help
I have exactly the same problem as PASHN8
My steering wheel module 16 is exactly the same with VCID, and same CAN gateway. I have white MFD. Like I said I have exactly the same problem as PASHN8 this means that I can see the phone menu in MFD but none of the steering wheel buttons work (Up, Down, OK etc.) and hence I can't confirm the passkey send by my phone on the car.
My setup is 9w7 latest version J module, RNS-510 with latest HW and SW. Below is my full VCDS scan. Car is 09 REG UK Passat
VCDS Version: Release 11.11.5
Data version: 20121222
Wednesday,27,February,2013,11:53:37:65237
Chassis Type: 3C0
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 56 62 72
77
VIN: WVWZZZ3CZ
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QD HW: 03L 907 309
Component: R4 2,0L EDC G000AG 3733
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 77FBAEE7063391A0106
Readiness: 0 0 0 0 0
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1918
Revision: 04844002 Serial number: 00000811081420
Coding: 0000020
VCID: D1AFB07F48176F907E2
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Revision: --025--- Serial number: 00000786466866
Coding: 0001301
VCID: 2F6B5687BEE39960886
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70E995FB635DC698D1C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009013330
Coding: 00888F0700041A00470A00000F000000000859435C000120000000000000
VCID: 326D5FF3ADD1B488E78
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 311008 022 0601
Coding: 00046997
Shop #: WSC 05124
Revision: -------- Serial number: 97540834412545
Coding: 300103
VCID: F1EF10FF28574F905E2
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__00Q VW10 HI 1815
Revision: 19013000 Serial number: 0039DPRQR9U/
Coding: 0012369
VCID: 3B7372D77A9B75C034E
Coding: 0001312
VCID: 6DD78C8F746F2B70FAA
Part No SW: 3C0 920 971 R HW: 3C0 920 971 R
Coding: 460D00
VCID: 346159EB9FC5BAB8F54
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Revision: H13 Serial number: 3300P08C150615
Coding: FDA07F06400602002003
Shop #: WSC 05314 123 12345
VCID: 2A5D47938501FC485F8
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 43
Mileage: 150440 km
Time Indication: 0
Date: 2108.14.15
Time: 20:51:07
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 7AFDB7D335218CC86F8
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H64 4020
Revision: AB001001 Serial number: VWZ6Z7K5120122
Coding: 04000402040000800000
Shop #: WSC 01324 020 00200
VCID: 33635AF792CBBD80ECE
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Revision: 72009005 Serial number: 00000684489112
Coding: 0000693
VCID: 6FEB96877E63D960C86
Component: EPS_ZFLS Kl. 196 2501
Revision: 00H15000
VCID: 2C51418B8FF5E278AD4
Component: KSG PQ46 ELV 043 0612
Coding: 0891020051030E763004941FF0085FCE107801
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Revision: 72009005 Serial number: 00000510989119
Coding: 0000692
Address 53: Parking Brake Labels: 5N0-907-801.clb
Revision: 009 Serial number: 00000000217990
Coding: 0000057
VCID: 2859BD9B9B0DCE5849C
Revision: 41004101 Serial number: 00000000754232
Coding: 0000144
Revision: 41004101 Serial number: 00000000759785
Coding: 0000144
VCID: 71EF90FF6857CF90DE2
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663335927
Coding: 0A10000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_VW46.rod
VCID: 397F68DFB8A747D0262
I have made the bluetooth working if I de-select Telephone (77) in CAN Gateway (19). The phone doesn't ask for a PIN and straight away connects with the CAR. Maybe I should setup a PIN in the Telephone (77) module.
De-selecting Telephone (77) disappears the Phone menu from MFD.
Error in CAN Gateway (19) is due to not selecting Steering Wheel (16) and Telephone (77) in CAN Gateway. If I select both of them then the error below goes away
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 43
Mileage: 150440 km
Time Indication: 0
Date: 2108.14.15
Time: 20:51:07
Coding: 0001831
VCID: 76E8EC587857
Coding: 00000227
Shop #: WSC 00000
Your steering wheel is different from ours and is reflected from the steering wheel Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC as well. Are you saying that we should change the steering wheel and that should solve the problem? But how come all the buttons work in other MFD display areas i.e. SETUP, Radio, Navigation etc. but not in this one phone menu? I am open to any suggestion
1 - 9 of 9 Posts
