1 - 6 of 6 Posts
I am trying to replace the bulbs in the inner headlights with new H3 bulbs, but I’m not understand how I undo these clips in order to replace the bulbs.
83203
Sorry for such an amateur question, I am new to working on cars, but I’m trying to learn.
Unfortunately it doesn’t seem to be in the Bentley Manual either.
Any help is appreciated! Thank you!!
You are supposed to twist them to the slot,and they will part ways of the Grille and as they are brittle they will part ways.
Here is how I did it.
That white clip is not factory and is a terrible way to splice wires.
Are you trying to remove the bulb or the light housing? You should be able to pull the rubber boot off the back of the light to access the bulb and replace it.
Sent from my SM-G970U using Tapatalk
Thank you all for the replies!! I wound up just removing the rubber boot and replacing the lights without removing the clips. Thanks again everyone!
1 - 6 of 6 Posts
