Re: (an_a6)
Quote, originally posted by an_a6 » |
This may be an extremely stupid question, but Ill ask it anyways. How will you see out of the windows after a few uses? Wont the same cause them to get "sanded," ultimately making them foggy and hard to see out of? |
Hardly a stupid question at all. I've purchased sheets of mylar with double-stick tape around the perimeter. It is sacrificial and is easily peeled off and replaced.
The largest gloves I could find are not big enough. They are a size 12 1/2. The fingers are plenty long. I just can't bend my fingers very comfortably. The manufacturer is getting some gloves in that are "ambidextrous" and have room for bigger fingers. Told me to keep these. I figured I'd try to stretch them out. Until he sends the new ones I'll suffer.
Most sand blast cabinets I've seen have 6" portals. The commercial gloves are designed for 10" diameter portals. They fit perfectly on a 10" ductwork take-off. I positioned them where they are comfortable for me. I simply held a pencil in each hand at a comfortable height to mark the center. They're about 8" further apart than a standard blast booth. Since my shoulders are 24" across I now understand why it was so uncomfortable and awkward to use a standard cabinet.
Added some handles for the side doors. They sit on rests to keep the doors aligned and need to be lifted slightly, so leftover handles from another project fit the bill.
My tinknocker friend came by and built the funnels and bent a flange for the back wall metal.
I needed a means to get the sand from the pressure pot to the blast chamber. I had some fittings left over from the soda-blast conversion so I devised a bulkhead fitting the would get the sand where I want it. By passing it through the wall in the center I can use it in either bay. The fitting swivels as it passes through the wall so there will be more flexibility. I used reinforced 1/2" heater hose on the inside of the booth. By loosenng two clamps I can return the blaster nozzle to the tank when I want to use it outdoors. That's not going to happen any time soon as it was -10° yesterday.
I installed a shut off so that I can quickly shut off the blast nozzle if a hose ruptures or comes loose.
Gloves, funnels and back wall metal installed.
Sacrificial mylar sheet. It attaches with double stick tape. Prevents etching tempered glass window. Simple to peel and replace.
It's pretty close to complete. All that's left to do is the grating above the funnels and hooking up the ventilation.
I have a diamond grit hole saw that I use for installing recessed lighting in plaster ceilings. It's 6 3/8" diameter, perfect size for 6" ductwork. The outlet of the fan motor is 4" x 6" or 24 square inches. I'll modify a 6" ductwork boot to transition to 6"round. I picked a position in the 12" thick block wall where I would only have to cut through one of the webs. I drilled a 1/4" pilot hole and drilled until the saw bottomed out.
It had cut through the side of the block, but no deeper before it bottomed out. Repeated deepening of the pilot hole allowed me to remove just the material necessary to get the pipe through.
It might have been a little easier to do some of this from the outside, but then, I didn't have to deal with this.
