1 - 10 of 10 Posts
I am looking to purchase these Mercedes rims from E-bay, and the bolt pattern is 5x112, so they are a direct bolt on for VR6's, right?? If so then I am going to save up for VR suspension, and throw these wheels on...Does anybody have Mercedes wheels on their MK3, I think I've seen a couple on here...Thanks in advance... http://****************.com/smile/emthup.gif
[Modified by VEEDUBJETTA, 8:30 PM 8-1-2002]
Re: Anybody Running Benz Wheels??? (Thorax_Embalmer)
Wont bolt right on, vr6 bolt patterns are 5x100. In order to bolt them right on you would need some adapters, to convert your 5x100 to 5x112
Re: Anybody Running Benz Wheels??? (VEEDUBJETTA)
if I'm not mistaken 5x112 is the Audi/Passat bolt pattern as well. You can get the H&R adaptors from Potterman's to convert from 5x100-5x112
Re: Anybody Running Benz Wheels??? (turboit)
ohhh btw be very careful about offset. the adaptors are going to be at least 15mm thick, so you need an offset with 15mm higher # than you want to have in the end
ET45 and more is the way to go if you're on stock fenders
[Modified by LostBoyScout, 12:50 PM 8-1-2002]
1 - 10 of 10 Posts
