1 - 9 of 9 Posts
...hit something the other day... that little raised part of my oil pan where the drain plug screws in is ground flat and the plug now has one more side than it used to
Somehow the grinding made the plug come loose too and I was losing oil.
Can I just get somebody to weld a piece of steel to the bottom of the pan ? So that the plug area will be protected a bit... In case of more scraping.
Re: Anybody tried welding a steel plate to your oil pan ? (MAC)
A good idea, but think about this ... if your scraping now, think how bad you will scrape with an extra 1/4" of steel sticking down from your oil pan.
· Banned
If you are that low I assume you have coil overs. Why not just raise your car a 1/2 inch? with it that low you are prematurely wearing out your tranny by shoving the axles farther in then they are suppose to be. It looks real cool until you have to come up with $3000 for a new tranny, because you can guarantee that it won't be covered under warantee
Re: Anybody tried welding a steel plate to your oil pan ? (late_apex)
quote:[HR][/HR]If you are that low I assume you have coil overs. Why not just raise your car a 1/2 inch? with it that low you are prematurely wearing out your tranny by shoving the axles farther in then they are suppose to be. It looks real cool until you have to come up with $3000 for a new tranny, because you can guarantee that it won't be covered under warantee[HR][/HR]​
how is he shoving the axles into the tranny further?
ive been rollin slammed for 2 years and havent had any poor side effects
(except replacing oil pan frequently)
lol. Raise the car? That is never an option. Coil overs can only be adjusted to a lower point... it's one of the commandments in "the brotherhood of the coils".
Re: Anybody tried welding a steel plate to your oil pan ? (Lobstrosity)
lol. Raise the car? That is never an option. Coil overs can only be adjusted to a lower point... it's one of the commandments in "the brotherhood of the coils".[HR][/HR]​
So very well spoken http://****************.com/smile/emthup.gif
I would rather make a bolt-on skid plate, than weld one to the oilpan. If i ever get my lazy ass to measure the undercarriage a bit, in reference to the oilpan, I will design a skid plate.
i just got to set the bong down first.
· Banned
Re: Anybody tried welding a steel plate to your oil pan ? (veedubGT)
Ok, I was told by a mechanic that is VW certified that when you lower the car to much it causes unusual wear to the tranny due to the angles that the axles are pitched at. This guy had tons of racing experience I would tend to listen to him, you don't have to obviously I'm just offering my advice. I had a friend that had to have his tranny replaced, twice. The reasoning that was given to him by volkswagen and a few other mechanics was that the car was too low and he had changed the geometry to the point that it was wearing the internal gearing in the tranny(rounding off teeth). He didn't believe them the first time either, by the second time he was a believer. I'm not ragging on anyone here, cars that are super low look great, they are just impractical to drive in most situations. Not to mention that after a certain point the handling starts to be affected by the limited travel. Hey if you want to lay your car out on the ground and replace parts every six months(oilpans included) then have at it. I am simply trying to offer some of my experience as advice. I've had cars that sat less then 1/2 inch off the ground, a few people in here can verify it. I was king of the ghetto slam, but over time I realized I wasn't getting the performance I wanted and for some reason kept sprouting oil leaks. Needless to say now I only lower to increase handling no lower. Remember super low is good on a track but then again most of them are fairly smooth compared to a city street. Take my post as you will.
late_apex
1 - 9 of 9 Posts
