Thanks, I'm going to look online at the salvage yards. I think I can get an OEM spare tire sub for a reasonable price. It is standard on the Fender system across many different VW car models for several years nowjust do a search....on google. I have seen ONE thread where someone put in all aftermarket speakers, did not touch the headunit. Another thread on this forum where the guy put in a plug and play "Match" system for a powered sub. The match system is made by some company in europe that supplied OEM speaker setups for various car companies. While it is plug and play, it is essentially a wood box with speakers in it. You need to conceal it and the amp somewhere. Lastly, there are various threads where people have installed a spare tire mounted, powered sub. The JBL brand sells one that looks like the best, there are probably 4 of them out there. It mounts inside of your spare tire and is totally concealed. You tap into the rear speaker wires for the sound signal and need to run a power line from the battery under the hood to the trunk. Not THAT hard, but you are taking things apart.
Oh, this is all on the atlas, havent seen anything on a cross sport.
there is one other kit out there by enfig stere that uses a mini pioneer amp that is plug and play. It mounts behind the cd player int he glove box and doubles the wattage of the OEM system. There are a few on the jetta forums who have used it. It has been tested on the Tiguan. I ordered it for the atlas and while enfig thinks it should work, I have not seen anyone with it installed.
All in all, there is not much out there on the internet yet.
It is indeed crap. I replaced the original speakers with Infinity Kappa components, and with a small JL amp (75 x 4) it blew away the fender system. I didn't have a CS but entertainment wise the cars are the same.Has anyone changed the speakers in their Cross Sport because for 41k what an embarrassment? The fender system is no big woop but the standard system wow.
I used the JBL BassPro because it fit in the spare. I had the seats down all the time and didn't want to build a box under the floor. For plug and play it was great, and easier to remove when I sold it then if I had built a box.The JBL brand sells one that looks like the best.
exactly, spot on.It is indeed crap. I replaced the original speakers with Infinity Kappa components, and with a small JL amp (75 x 4) it blew away the fender system. I didn't have a CS but entertainment wise the cars are the same.
The connectors used in the einfig harness/amp are available separately from Scosche and Metra. The amp I used had speaker inputs so it was pretty simple to extend the harness wires and the sound was so much better even without a proper line-out converter. The amp and both ends of the harness cost less than $75 more than the einfig. The einfig setup will give you a lot more volume even with the OE speakers, but it's a low-current chip amp so it won't give you much benefit at low volume levels and it doesn't have the headroom to increase the bass levels much before it clips (which is probably only an issue for most people if you aren't adding a sub).
I followed your lead and boughtIt is indeed crap. I replaced the original speakers with Infinity Kappa components, and with a small JL amp (75 x 4) it blew away the fender system. I didn't have a CS but entertainment wise the cars are the same.
I don't have the fender system so im not sure if the regular Atlas crosspost has tweeters i see what you say about the amp and im switching amps thankswhat about the oem tweeters? will you just abandon them?
That is also a pretty low-end amp that has been replaced by RF. The replacement, Rockford Fosgate R2-300X4, is a class D, the one you got is AB.
the regular system has tweeters in the door by the door handle, not just the fender.I don't have the fender system so im not sure if the regular Atlas crosspost has tweeters i see what you say about the amp and im switching amps thanks
@brian81 - Thanks for posting details of your setup. Would you be able to list the harness adapter that you used from einfig? They don’t list the Atlas Cross Sport as a supported vehicle - maybe it was the ENFIG_AAI4_VW16?It is indeed crap. I replaced the original speakers with Infinity Kappa components, and with a small JL amp (75 x 4) it blew away the fender system. I didn't have a CS but entertainment wise the cars are the same.
Yes but looking to see if anyone added specifically the spare tire sub when there was none to begin with. I think JBL and Rockford has one.did you see the post JUST above yours?
awesome! any pics? where did you tap into for audio? how about power?Yes, and I specifically just did just that.
