Re: Anyone changed a starter in 1.8 16v???? (bollo)
The first time I tried this, I thought I'd made a grave error too - after figuring out the problem, it's just a matter of patience and some physics.
quote:[HR][/HR]Now i cannot get the starter bolted back in because the bolts don't line up...not even close, about an inch off!!! What the hell is wrong here??? I tried to put a jack under there and lift the tranny back into place, but it didn't work... just started to lift everything...Now i'm worse off then when i started
HAs anyone experienced this???
[HR][/HR]
You're on the right track - use the jack to position the transmisison. Eventually you'll lift the trans high enough that it'll line up with the motor and the starter bolts will slide in place. Remember that by removing the starter and it's bolts, you've effectively removed the front motor mount. This means that you'll have to finagle the trans, engine and starter bolts around to get it all back together.
[HR][/HR]
