1 - 20 of 22 Posts
Now that my R32 has around 700 miles, I decided to further test its abilities on the open road. I find that if I launch hard and shift in the upper rpm range, I hear a loud thump coming from the back. Is this a result of the 4motion briefly kicking in?
Just curious if anyone else is experiencing the "thump".
Re: anyone else experience this when shifting hard? (euro sport)
Happens to WRX drivers a lot, especially if the shifts aren't executed perfectly - in our case it's the Diff popping a little. It's nothing bad, but nothing good either.
Re: anyone else experience this when shifting hard? (Emikandi)
How do you know that you are shifting properly? Lets say you are in 5th and want to drop down to 3rd? do you rev the engine then go into gear. get the RPM's up and go? just curious. Thanks
Re: anyone else experience this when shifting hard? (Cackleberry)
Thanks cackleberry. That is what I thought. Just thought i would throw it out there anyway.
Re: anyone else experience this when shifting hard? (andru1313)
Mine makes a "thump" but that's just the damn engine/driveline shock when I slam gears and it come from the front. Handles it really well though - The 02M ROCKS.
Reving the engine and upshifting is actually part of the process of "double clutching" or "skip shifting" The popping is lessened if your use your clutch at the correct intervals throughout the shifting process.
I am a little confused with this idea. If one is shifting hard, regardless of RPM (although higer RPM does force more HP on the clutch plate), what is the bump? It couldn't be from engaging the clutch at the wrong time (unless past redline), could it? I mean, a car is able to shift at any point through the RPMs. Roll-offs and trailers have big enough gears to find the "right" interval at which they can shift (without even using the clutch pedal), however, I am assuming everyone is stepping on the clutch pedal first which should completely prevent any kind of grinding or clutch slippage.
Around 3-3500RPM I can hear the exhaust not really change and its very noticeable. Is this normal? I am thinking it is the vacuum line in the exhaust.
Thanks in advance guys!
It's just the Haldex unit in the rear engaing the rear wheels. None of you guys ever drove 225hp TT? They can do it to, my friend's chipped 225TT does it pretty hard.
Discussion Starter · #11 ·
Re: anyone else experience this when shifting hard? (pumpkin02)
This is my first vehicle with all-wheel-drive capabilities.
The 4Motion system on the R32 is actually always engaged, so there shouldn't be a loud noise of the car engaging the rear wheels. I have accelerated pretty hard in my R32 a couple of times and haven't experienced that noise at all.
-James O'Connor
Re: anyone else experience this when shifting hard? (SkankyBeans)
You sure it isnt the exhaust rumble when you lift off the gas to shift gear?
Quote, originally posted by SkankyBeans »
That is incorrect. The whole reason Haldex was chosen over other AWD systems is because
it only engages when needed (which it does very quickly) and is otherwise a front wheel drive
biased system with lower drivetrain loss and thus higher fuel economy.
If he's hearing this only when shifting hard from 1st to 2nd (where you'd normally get some
wheelspin in a 240hp FWD car), then yes it could be Haldex clutch engaging and a tiny bit
of rear drivetrain lash.
ian
Re: anyone else experience this when shifting hard? (Daemon42)
Quote, originally posted by Daemon42 »
Bingo!! http://****************.com/smile/emthup.gif
The Haldex system is a set of wet clutches. They can bang when they engage just like a FWD car when shifting hard 1st to 2nd. I have a VR6 PP and disc in my GTI, and when I go hard into 2nd, it hits pretty good.
Re: (plf)
Quote, originally posted by plf »
there is a difference between shifting hard and shifiting fast & smooth
Re: (ced)
Quote, originally posted by ced »
I don't think there's any mystery to what he meant by shifting hard.
We're talking a shift that in a FWD car would break the front tires
loose on a 1->2 shift.. and sometimes even get a chirp out of 2->3.
We've all done it, and sometimes it's even the fastest way down the track
or light to light, or whatever (about 10-15% wheelspin is better than none for
max accelleration on dry pavement, depending on tires). With the uber short
gearing the R32 has, and its fat torque curve if it were FWD-only, it'd
spin the tires most of the way through first, then spin them again on a hard 1->2 shift.
That explains why Haldex might be activating along the way.
ian
Re: (Daemon42)
ian
Thats my point exactly. It is not a FWD car, hence your driving style has to adapt or suffer the consequences of premature powertrain wear. Nothing against the person posting but I know a few people that go thru clutches and trannies just because of their bad driving habits.
ian
I stand corrected. Thank you Ian.
-James O'Connor
Re: anyone else experience this when shifting hard? (vw_chris)
Quote, originally posted by vw_chris »
1 - 20 of 22 Posts
