I've replaced a bad TB (TPS died).
Clean the area around the TB, top, sides, etc. debris = bad inside intake.
Basically remove the air box, remove the MAF tubing as a whole, TB can be Carb cleaned in place, just make sure that there is no debris that might get sent into the intake. The gasket goes for about $7. To remove the TB and clean it (IMO slight overkill), the electrical connector needs a small flathead screwdriver slid into the catch from the dashboard side of the connector. (towards the front of the car.) Allow lots of drying time 1 -2 hours to eveaporate excess spray fluid. Clean the MAF while your at it (carb cleaner is fine).
VAG-COM when reassembled.
