Has anyone seen a Tiggy on Golf Alltrack 18" Canyon wheels? I'm looking to get a set of winters together for my inbound Highline R-Line and a set popped up on the local classifieds that I am considering.
Do you have any more pics?2022 SEL R Line
Rotiform TUF Forged Monoblock: 20x9 et 25
Michelin Cross Climate 2: 255/45/20
+5mm spacer in the rear
Warm/Hot season wheelset.
Rear: Showing 285/35R20 ET30
y
What offffoffffoff set are you running
Front: Not fully shown, 255/40R20 ET30 with Neuspeed Caliper-370mm
What offset are Both wheel sit flush to wheel fenders. Not going to lower the Tiguan until it's needed in another 3 Years after I get a new SUV.
Does anyone know the weight of the 2022 factory SE Rline wheels?2018 Tiguan Wheel Fitment
Does anyone know what the wheel fitments are for the 2018 Tiguan? 17" and 18" including offset?
Thanks
Do you have any rubbing with the 22s. To be honest your the first at least that I’ve seen running 22s on a tiggy. I’ve seen a few guys running 20s on coil overs and they rub when turning or under a heavy load so wasn’t sure if you had a similar issue, or if you just adjusted your ride height to avoid it.I'm sitting on 22x10 et 20 on 235/35s and im also lowered on Solowerk S1 as well![]()
Sent from my SM-G988U using Tapatalk
Looks great! What size tires are you running?
Looks amazing! I saw in your other post you're running 20x10.5 et 27. What size tires are you running? Any spacers? Much appreciated!
285/35/20 no spacers perfect fit!Looks great! What size tires are you running?
Did you need any spacers for this set up or did they fit right? I keep seeing the cadiz in ECS and it says “it doesn’t fit” to a 2018 tiguan (I have same tiguan as you)19” Cadiz
This setup looks great. How is the ride? Are these rotiforms?I'm sitting on 22x10 et 20 on 235/35s and im also lowered on Solowerk S1 as well![]()
looks good! i'm so ready for the weather in new england to stop sucking so i can clean mine up and put my coilovers on.Put these on last week, 20x10.5”. Because the design of the wheel arch’s / lips on the Tiguan I could get a good flush fit with the stock wheels as even without spacers they would rub on hard bumps (former softer coil overs too) so used the stock 255s with stretch so I could get the fitment that I wanted on the wheels and still clear the fenders on compression. Typically I never wanted a stretch tire look at all (my gti runs a 265 on 8.5 currently 😂😂) but had to do it to get the final look I was really after, and in the end I’m more that fine with the stretch and very happy with the look overall.
wheels are ET45 with 15mm adapter/spacer on both front rear , **5mm clearance from the wheel hub to larger aftermarket strut body in the fronts.. so very tight!
View attachment 167290 View attachment 167289 View attachment 167286 View attachment 167287 View attachment 167288 View attachment 167285
