1 - 9 of 9 Posts
Discussion Starter #1
Well since I've changed the cables and put whatever vacuum line on the rocker, it had worked until now. The moonroof is now intermittently making the dreaded "pop" noise. I remember Ken93P-GLX used some sort of product that I couldn't find around here, just wondering if anyone had an extra 1/2" they could send my way?
thanks, Morgan
Discussion Starter #4
Re: Anyone have an extra O-ring for the moonroof rocker? (TBT-PassatG60)
Get back on topic, baster!
The O-rings, it's all about the O-rings.
Re: Anyone have an extra O-ring for the moonroof rocker? (BC Dub)
Probably can't get it seperately from the stealer hey?
I might have one, but i'm not too sure what / where this part is located.
Discussion Starter #7
Re: Anyone have an extra O-ring for the moonroof rocker? (N'Syncro)
Quote, originally posted by N'Syncro »
The dealer sells them with the rockers
My rockers aren't broken. The reason I'm looking here is because a few people have used a vacu-tite (I think that's the name) part number that I couldn't find around here.
Used ones are no good because they are generally worn out.
I just cut a "sliver" of about 3/16 vac. hose, slipped it on and works fine.
Discussion Starter #9
Re: Anyone have an extra O-ring for the moonroof rocker? (TrueValue)
I just couldn't seem to find a hose where the thickness of the rubber was enough. Either the inside was too big and it fell off, or the outside was too small and it still caught. Suppose I could keep looking locally...
1 - 9 of 9 Posts
