ANYONE RUNNING WHEEL SPACERS?
1637 Views 31 Replies 19 Participants Last post by  1300driver
2
I want bring the back wheels even with the fronts...anyone running spacers on the back with stock wheels? if so post pics.
Any recomendations on what thickness is good to go with?
Modified by jonny_breakz at 7:17 AM 7-1-2003
See less See more
1 - 20 of 32 Posts
Re: ANYONE RUNNING WHEEL SPACERS? (jonny_breakz)
i'm running 20mm OMP spacers on the rear with stock 15" BBS. they only rub a little under hard bumps. http://****************.com/smile/emthup.gif
See less See more
Just FYI, adding spacers to just the rear of your car will have an adverse affect on handling (more understeer). I can't tell you just how much of a difference it would make, but if you're not going to auto-x/track your car, it probably won't make that big a difference.
Re: ANYONE RUNNING WHEEL SPACERS? (glidrew)
Quote, originally posted by glidrew »
any pics?? I am also going to be running a set of 15 x 7 BBS's shortly
Modified by jonny_breakz at 9:30 PM 7-1-2003
See less See more
Re: ANYONE RUNNING WHEEL SPACERS? (GTiRacer53)
Quote, originally posted by GTiRacer53 »
Thanks for the Tip....but its a cabby and it is not build for any kind of racing...its just a cruizer...
See less See more
I've got spacers on my 88 cabby. I am running 205 40 17's and needed the spacers because the lugs were too long. No problems or rubs. Can send you pics if you need it...
Re: ANYONE RUNNING WHEEL SPACERS? (cabs88)
8mm in the back...needs to be like 15mm
See less See more
Re: ANYONE RUNNING WHEEL SPACERS? (R3)
I know it's off topic but I have the same color cabby and I was wanting to keep it the same color but what bumpers would look good with the gold color?
Why, gold of course.
Re: (Speedemon)
lm also running 8mm spacers out back with my 16x7. Ony reason I am is because the right rear tire was rubbing on my H&R springs. When I setup my suspension with Ground Control and if there is enough room I will be removing the spacers becasue of the handling affects. I dont notice that much but Im sure if I really pushed it maybe.
2
Quote, originally posted by R3 »
You really wanna space that out a bit more?
I think it looks great. I think I'll get me some
wheel spacers but what size I'm rockin some teardrops
on my cabby, I think that at least the 8mm might just
go for the 15
thanks for showin us how your 8s look
See less See more
Re: ANYONE RUNNING WHEEL SPACERS? (JJenkin5)
Quote, originally posted by JJenkin5 »
well chrome looks good..and so does black....or the black plastic euro also look nice...
heres a pic with 20mm spacers...
its the only pic i could find
See less See more
Looks good from that angle...would like to see it from the rear. Do you notice any difference in how your car handles?
See less See more
Quote, originally posted by jonny_breakz »
lets see some more pics of this, i'm wanting some spacers for mine but don't know what size to get...i was thinking 20mm but want to see more pics
2
Re: ANYONE RUNNING WHEEL SPACERS? (1lowcab)
I finally got some pictures up. the rears have two spacers each of about 14mm
finall spacing is between 28 and 30mm
Hope that helps
Oh forgot to dsay that it's running stock suspension so if i want to lower it i'll possibly have to take one of the spacers out. We shall see
See less See more
4
Re: ANYONE RUNNING WHEEL SPACERS? (1300driver)
Quote, originally posted by 1300driver »
Hope that helps
Ohhhhh I like http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Let´s see some more pic´s please!
See less See more
7
Re: ANYONE RUNNING WHEEL SPACERS? (Goffe)
since the bottom ones were taken i have since 'chromed' the grille
See less See more
nice one for sure!
But u need to slam that.... alot!
Never fear...I is here
It shall be, couple of weeks time should be on the weeds, though not sure if it'll go as low as i want it on the ronals. will just have to see, want to get some deep 13's for it. know of any i should look out for, i like the Starmags that are on some old Minis
1 - 20 of 32 Posts
