1 - 1 of 1 Posts
Vendor
The APR Full Carbon Fiber Intake System for the Audi S6 and S7 (C8) 2.9T EA839!
This is the ultimate intake upgrade for the Audi S6 and S7 (C8). It flows 33.5% more than stock, reduces pressure drop, and improves linearization across the turbos. This directly translates to +23 AWHP and +21 AWFT-LBS of torque making this a simple upgrade for more power you can feel.
Get the details: APR Carbon Fiber Intake System - C8 2.9T S6 and S7 - APR
Our system is a full upgrade as it replaces all of the intake components from the inlet scoop all the way to the turbo inlets. This is extremely important as focusing on the airbox alone does not address the main restrictions found in the factory intake system. Simply put, our system flows better than stock, makes more power, puts less strain on the turbochargers, looks sexy under the hood with the gorgeous carbon fiber design, and enhances the sound of the engine.
Features and Benefits
  • Full intake system: Inlet, airbox, filter, and inlet piping
  • +23 AWHP & +21 AWFT-LBS measured over stock
  • Flows 33.5% more than stock
  • Reduced pressure drop at the turbo inlets
  • Improved linearization across the turbos
  • Enhanced engine sound
  • Carbon fiber construction
  • Turbos spool faster
  • Turbos operate more efficiently
  • Massive 7” x 7” filter with a 4” outlet and 5.5” frontal inlet
  • High flow and washable pleated cotton gauze filter material
  • Airbox open away from engine to maximized flow and filter size in a restricted space
  • Inlet piping diameter is maximize from the 4” filter all the way to the turbochargers
  • Inlet piping addresses system restriction, unlike competitive airbox systems that are compatible with factory inlet piping
  • Billet turbo adapter rings make fitting this system to larger turbos possible
  • New OEM gaskets included
  • Emissions friendly
Want more info, photos, dyno graphs, and flow bench charts? Visit our website!
1 - 1 of 1 Posts
