APR is pleased to present the ultimate Cast Inlet Downpipe Exhaust System for AWD 1.8T and 2.0T vehicles!
The APR Cast Inlet Downpipe Exhaust System replaces the restrictive factory downpipe with a larger, 76mm stainless steel mandrel-bent system, featuring a port-matched cast inlet, high-flow catalyst and various other features. Expect better throttle response, more horsepower and an intoxicating exhaust note, while remaining civilized during normal daily driving. It’s one of the best performance upgrade for 1.8T and 2.0T engines following APR’s ECU Upgrades and it’s designed and assembled in-house, using premium materials and world-class manufacturing techniques few can match.
apr_exhaust_mqb_awd_upper_2
Quick facts:
  • More power, torque & less lag+24-36 HP & +29-41 FT-LBS over stage 1!
  • Larger, 76mm systemSay goodbye to the restrictive 65mm system!
  • Cast Inlet with port-matched v-band flangeUnrestrictive flow for maximum performance!
  • Premium T304L stainless steel constructionOnly the best to resist corrosion and stand the test of time!
  • Premium argon back-purged TIG weldingClean, strong and attractive welds, inside and out!
  • Strong GESI high-flow catalytic converterReduced emissions, smell and noise without the power hit!
  • OEM-style slip-on clampsSlip on and go with no pipe deformation!
  • OEM-style internally-corrugated flex sectionFlex without the common failures and restrictions!
  • In-house design, assembly and quality controlEngineered from concept to reality to be the best!
  • Plug and playBolt on and go with the included instructions!
  • APR Stage II ECU Upgrade price waivedUpgrade from APR Stage I to APR Stage II for free!
  • Limited lifetime warrantyThe best system with the best warranty!
Downpipe with Cast Inlet
The APR downpipe features an investment-cast inlet, with a port matched v-band flange, creating an ideal flow path for exhaust gasses exiting the turbocharger. By matching the already oversized turbo outlet, the downpipe is able to maintain exhaust gas velocity, improving performance with minimal variances in cross-sectional area due to the strategic use of cast parts. Furthermore, the cast inlet allows for excellent packaging, satisfying other design criteria while maintaining a larger and constant cross-sectional area compared to mandrel bent tubing built to similar specifications. The end results it simple: Smooth exhaust flow and maximum performance!
apr_exhaust_mqb_awd_cast_inlet_2
The downpipe’s piping is upgraded to attractively-brushed, straight-through and mandrel-bent 76mm tubing, dwarfing the small 65mm factory system. Furthermore, components visible from the engine bay are tumbled for a more attractive finish. A CNC laser cut bracket provides a strong and accurately positioned mounting point to take the weight of the downpipe off the turbocharger, and the internally-corrugated flex section gives the downpipe the flex it needs under engine movement. Finally, the downpipe uses T304L stainless steel components that are TIG welded together with argon back-purging, ensuring the system not only looks great on the inside and out, but stands the test of time.
76 mm Midpipe
The factory midpipe uses awkwardly-kinked, 65mm tubing with some systems featuring an additional midpipe catalytic converter. The APR midpipe eliminates the front resonator, giving the exhaust a slightly more aggressive note, while eliminating performance robbing restrictions. Finally, the midpipe uses attractively-brushed mandrel-bent 76mm T304L stainless steel tubing.
apr_exhaust_mqb_awd_midpipe_1
Flex Section
The APR midpipe use an OEM-style flex section that is fully sealed with a corrugated inner lining to improve flow and reliability. The low profile design and minimal use of bradding material eliminates clearance issues common with other designs that can billow, rub, rattle and fray over time. The flex section is constructed from T304L stainless steel and is argon back-purged when TIG welded to the downpipe.
apr_exhaust_mqb_awd_flex
Catalytic Converter
APR’s engineers specified a high-quality and high-flow GESI metal 300-cell catalyst ideal for forced induction application. During dyno testing, the 100mm x 100mm design showed no measurable loss in power thanks to the catalyst’s design
apr_exhaust_universal_catalyst
Internally the catalytic converter feature a proprietary wash coat that helps to reduce emissions and smell common on cat-less setups. The low-profile catalyst features a fully captured substrate brick, which is furnace braised to the outer mantle and physically captured by the diffuser cones preventing rattling, rotation, and damage to the substrate. Subsequently, a byproduct of running the catalyst is a reduction in noise, making the system as a whole more pleasing to the ear.
Brackets
Attached to the downpipe is a high quality mounting bracket. The bracket is constructed from T304L stainless steel and is CNC-machined and CNC-bent to exact tolerances. The bracket is TIG welded to the piping and argon back-purged.
apr_exhaust_25tfsi_bracket_1
Designed to stand the test of time, the adjustable bracket is CNC machined from 8mm-thick billet T304L stainless steel and the hanger feet are threaded into place, eliminating the need for welds. Weight is removed from the bracket, wherever possible, while not hindering its structural integrity. The bracket attaches to the downpipe’s integrated mounting bracket with the included hardware.
Clamps
APR’s engineers specified a T304L stainless steel, OEM-style exhaust clamp designed to eliminate the need for flanges, swedging, or slip fittings. By using this low profile design, the exhaust system can be positioned higher in the exhaust tunnel and away from the ground with better clearances compared to flanged setups. Each clamp allows for less turbulence and greater accuracy at the connection points as the pipes simply butt up to one another rather than the ambiguity and voids associated with swedged slip fittings. Furthermore, the clamp doesn’t rely on deforming the pipe to provide a tight seal, making install and removal more convenient.
apr_exhaust_40t_cast_downpipe_clamps
Oxygen Sensor Bung
APR’s Engineers paid special attention to the details when designing the APR Cast Inlet Downpipe Exhaust System all the way down to the oxygen sensor bung. APR’s O2 bung is investment cast from T304L stainless steel and is curved to perfectly fit on the catalyst, without protruding into the pipe, as this would further impede airflow beyond the sensor itself. The bung is TIG welded to the piping and argon back-purging is used to ensure the interior surface is smooth and clean.
apr_exhaust_b820t_cast_downpipe_bung
Reducer
A simple and removable, T304L stainless steel reducer, featuring a smooth transition, is included, making the APR Cast Inlet Downpipe Exhaust System directly compatible with the OEM catback exhaust system.
apr_exhaust_universal_reducer
Harness
A high quality oxygen sensor extension harness is included as the catalyst and sensor bung is relocated further away from the turbocharger.
apr_exhaust_o2_harness
Find out more at goapr.com.
apr_exhaust_mqb_awd_installed_2
