1 - 5 of 5 Posts
Re: APR ECMS Question (Bug_Power)
did a quick search and found this:
"Turn the car off and set the key to the on position (as far as it will go without the engine turning over, like you are switching modes). Turn on cruise. Hold resume until a light starts blinking and release. Two lights should flash alternatley to confirm lockout. The code is entered only when you are unlocking it. Next time try the APR website. They have pictures and instructions there. "
don't know if that'll help you or not...I have no experience with the ECMS
Discussion Starter · #4 ·
Re: APR ECMS Question (ruso)
tried the search for ECMS Instructions and didn't get anything....
However the car is a New Beetle... Only
off/on is the only thing labeld. Is the Set button the end of the stalk or is that the cancel button...cruse control on this car was turned off via vag-com or I'd check. It still works to change the programs...the guy did it just the other day. But we took the battery cable off and it went into lockout mode.
you have to know your security code. key on, engine off, cruise on, enter 1st number via set button, clicking it the to match the 1st number, then hit cancel, enter 2nd number same way, then hit cancel. do this for however many security digits you have. if you do it correctly, CEL and some other light flash alternately.
1 - 5 of 5 Posts
