Just upgraded from the i.e hpfp piston to a new Apr pump. Immediately after install noticed hesitation and fuel cuts.
Scanned with vcds and found rail pressure at 7 bar.
Taking the pump off I found the cam follower was shattered on the open side.
Bottom of the follower with black coating was fine.
I change followers regularly and have a few spare, when I initially installed the pump the lobe was flat in regards to it's rotation and the pump mounted flush to the housing
When attempting to reinstall the pump with another follower the cam lobe was at its high point and I was unable to seat the pump against the housing by about 1/4 inch
Not sure what's going on but I should be able to seat the pump flush with the housing regardless of the lobe position.
This led me to compare the apr pump to an extra stock pump I have and noticed the apr piston is longer than the stock pump piston in a side by side comparison.
My follower was good without wear it was less than two months old
Feel like I got a dud, it was new from ecs but didn't have the Apr sticker serial number like the ad shows.
Install was smooth wondering does anyone know if the apr piston is longer than stock?
Looking at pictures of the pump sent to me it appears the nut that tightens the piston into the fuel pump housing is outside the pump vs pictures on ecs website for the ad the piston nut is recessed deeper into the pump housing.
Stumped on this one waiting to hear back from apr
