Product Page http://www.goapr.com/products/intake_carbonio_20tsi.html
Carbonio's latest carbon fiber intake for the 2.0 & 1.8 TSI engine is a truly race engineered ram air design that is available for the first time as an affordable street car intake system. Building from years of experience on and off the race track, Carbonio's and APR's engineering teams have spent countless hours developing a true cold air and ram air carbon fiber design that can be recreated affordably for the street performance enthusiast.
For many years professional motorsport organizations have suffered great expense to properly tune the air intake delivery system for transverse turbocharged engines for use in endurance and sprint races where every last horsepower and pound feet of torque can make the difference in position when crossing the finish line. Historically these designs have proven to be the most efficient and powerful although the most expensive to produce.
Aftermarket performance companies have attempted to capitalize on these designs however the cost restraints have typically resulted in compromise and deviation from the true engineering principles associated with motorsport accomplishment. Don't be fooled by catch phrases and tag lines alluding to a new intake technology or special design characteristic. You won't see any of these gimmicks installed on race cars at the Nurburgring.
Carbonio and APR have gone even further to maintain all oem specifications necessary to integrate cohesively with an otherwise stock engine to avoid raising eyebrows at the dealership. Flexibility was another characteristic of Carbonio's and APR's design whereas the new TSI intake is also suitable for Stage 1 and Stage 2 modified engines all the way up to and beyond APR's Stage 3 Turbocharger System.
- Increased Horsepower and Torque
- Improved Throttle Response
- Decreased Turbo 'Lag'
- Improved Fuel Economy
- Enhanced Engine Volumetric Efficiency
- Enhanced Sound of Turbo Diverter Valve
- Installs in an Hour (does not require bumper or headlight removal)
- Maintains Clean Appearance by Retaining Factory Engine Cover
- Maintains All Factory Emissions Components
- Fits Both Manual and Automatic Transmissions
- Unique Thermal Barrier Composite Construction Ensures Low Inlet Temperatures
- Fully Compatible and Complementary with APR Software and Exhaust systems
Intake with EA888 Gen 3 adapter assembled
Adapter for EA888 Gen 3
Application Guide:
1.8T and 2.0T EA888 Generation 3 (CPKA, CPLA, CPRA, CPPA)
2013.5 Jetta, GLI, Beetle and Passat
5MT, 6MT, Tiptronic and DSG
Part Numbers and Price
CI100020 - $324.99 - Intake
CI100020E - $19.99 - Intake Adapter for EA888 Gen 3 Engines (Required)
CI100020A - $24.99 - Intake Filter for vehicles equipped with secondary air injection (Click here to see if you engine does)
