2018 Tiguan SEL-P there, with almost all bells and whistles here, except it is 2 rows, not 3, and some luxury missing on
the back such as heated sits and 3zone climate...
+ APR ST 1 RON 87.
Input
1. APR ST1 RON87 newly flashed
2. Long trip 3000mi with 3000lb behind in UHAULT trailer,
3. Warm fall time around 28-30 Celsious
The same incidents close conditions
4. Loong uphill overtaking with full throttle on, upshift from 3 5500rpm to 4 ~3500 rpm so more torque needed.
4.1 Next day, not the same day
Long standing idling (1h or so) with A/C on (probably heatsoaked Intercooler) overtaking traffic same story WOT + upshift from 3 to 4 again ~5-5500k rpm to ~3500krpm
got really hard loud as hell buzzing/ kind of knocking sounds from the motor, sounds like detonation but I'm not sure, and I do know how detonation sounds on N/A motors, and I'm still not sure even up to this date.
Eased up on the throttle instantly, and drove it all the way through never pushing it past 3/4 ish...or downshifting manually on the uphills etc. Rocky Mountain with heavy trailer were fun drive)
5. Later on(2 days later) got floating idle and check the engine with misfires in cyl 2. did not have spark plugs but had tools, took it apart, gaped it tighter by the eye, drove all the way to a new home without incidents but never pushed car hard.
Yes It was my stupid that I did not change spark plugs on the spot after the flash
it was at 50k km and the original spark plugs set.
6. Had not stable idle and at 55k km changed spark plugs for new original NGK, did not gapped them, left with original I believe 0.7mm gap, need to verify
Got stable idle but after 3-4k km got back to square 1 with fluctuating idle it jumps in between 760 to 815 rpm and I can hear and feel it!
Now, there is not a lot of load on the car currently, just drive around the town, never push it to the limits and not towing anymore for now.
7. It was not a GAS quality for sure as I used RON93, all the way, because of tune, and because I want to be extra sure, still did not help...
Questions
1. APR knows nothing, the response is "it is not us, it is you"
2. How to diagnose what it was and what to do with it?
I was not able to find misfire counters in VCDS, can someone point me to it?
How to measure ignition retardation with VCDS in our motors?
Budackh cycle is tricky with variable compression cycle... I saw it fluctuate all the way from -26 at idle to 0 trying to understand how to properly measure it.
3. Will colder spark plugs help? Can someone point me to the recommendations? ignition coils possibly?
currently, the car drives 3-5 km day max, occasionally 50-80km just around the town. Does it make sense to go colder spark plugs...
But in the summer planning to have a small camper towed into the mountain, do not want to repeat what happened above and blow up the motor...
And yes Tig is capable of towing non-braked 3000lb safely, yes you need to take it steady above 3500lb would be a question of sanity...might try braked up to 5000lb - but the engine (more of a gearbox actually) will struggle in a mountain with that.
The gearbox on the longest hill in Rocky got up to 119C at 110 km/h (65mi-ish) and the engine still had an extra to go faster, but I did not want to push it.
The trip was migration from Toronto to Vancouver if anything.
+ APR ST 1 RON 87.
Input
Questions
