Re: are #30 injectors a real noticeable mod? (vdubin90)
unless your running unreasonable boost or like to romp into the nether regions of rpm's (past your peak power band) for long periods of time, most stage 1-4 cars dont make power up that high.
Best way to find out is put your car on a dyno, where the air fuel dies off, you have to make a choice, more fuel, or don't drive it for any long period of time (3rd,4th,5th) in that region.
Each car varies because of many reasons, boost, age/condition of fuel systems. I like to go with the "safe" side and recommend no higher than 6000 rpm's for any period of time under boost given stage 1-4 trim and reasonable boost rates.
If you're charger is magical and makes like 17+psi at those rpm's or if you have flowed your head, put a bigger block in, then i suggest you choose larger injectors, a chip to match, and a dyno session.
It's always better to be safe than sorry, and most g60 dyno's show very little power gain (stock block/head/etc) over 6000 rpm's. Most.
Dyno run might cost you $65 for 3 pulls with air fuel, its a small price to pay to know where your limits are, imo. Push the limits, the car will push back, right at your wallet
