are these springs any good?
333 Views 2 Replies 2 Participants Last post by  wacktool
I have a 2.0 slow, are these spring good quality and will it be noticed that the car has been dropped while using 15's vw rims? Or do you think I should go with the vw springs?
http://www.parts4vws.com/catalog/product_detail.asp?PartNumber=55.10.88
1 - 3 of 3 Posts
2
Re: are these springs any good? (jettanjax)
If you're choosing between the 2, i would get the Neuspeed springs. Although i think they are much stiffer then the "VW" springs ( which are just Eibachs ).
The thing you may have to look out for , is when you mate stiffer springs to the stock shocks/struts, it may wear down the stock shocks/struts prematurely and cause some bounciness later down the road ( no pun intended
Although many people run just springs without any problem. http://****************.com/smile/emthup.gif
See less See more
Re: are these springs any good? (THE Wuss)
Thanks Wuss,
That is my plan right now, is to get spring to lower, and use with my OEM struts/shocks , untill later. So by getting lowering springs, it wont cause any damage to the car(except for accellerated wear on the oem shock/struts)?
1 - 3 of 3 Posts
