ash tray removal
404 Views 5 Replies 6 Participants Last post by  g60_c
anyone know how to take the front ashtray out? TIA
1 - 6 of 6 Posts
Re: ash tray removal (Keving60)
There should be a little black lever in the middle of the ashtray on the top of the inside. Kinda looks like a guide for it. Pull ashtry out till it wont anymore then press that lever down and pull out the rest of the way. Pretty basic, pretty much like all other ashtrays http://****************.com/smile/emthup.gif
See less See more
if you open the door and pull it will come out a little. then you will be able to see a metal tab in the top, press down on the tab and pull it out. http://****************.com/smile/emthup.gif
damn, didn't type fast enough!
[Modified by SMOKE2000, 4:25 PM 2-6-2002]
See less See more
Re: ash tray removal (SMOKE2000)
Get in the drivers side and lean the seat all the way back, put your right turn signal on and flash your highbeams 3 times. If that dosen't work just do what they said.
See less See more
Re: ash tray removal (fluid72)
be sure to wear clean underware also!
See less See more
Re: ash tray removal (ag602nv)
i find it helps if you grunt three times... and say "more power...."... grab a few
while you're it.. should make the job easier(or @ least more interesting... )
nate
See less See more
3
1 - 6 of 6 Posts
