1 - 19 of 19 Posts
ATP Turbine Housing heatshield Worth it?
From the site: "Turbine Housing Heatshield, Stainless Steel (Unpolished. Drastically reduces radient heat to protect other sensitive engine components. Easy 2 bolt install and fits all T3, T4, GT30 R style housings."
It's really worth it?
LMK
Re: ATP Turbine Housing heatshield Worth it? (jernest)
I'm wondering the same thing.
Anyone know if there is even room for this to fit behind a VR6?
That doesn't look very hard to make. A chunk of stainless pipe, and a bracket. I really wanted to get one, but now I want to make one.
Discussion Starter · #4 ·
Re: ATP Turbine Housing heatshield Worth it? (Agtronic)
Quote, originally posted by Agtronic »
If you said you want one.... Means that it's worth to get it.
ATP sell it for US$59 if you can make it for US$50 shipped I'll be all over it
Quote, originally posted by jernest »
If heat shields didn't do anything, do you think manufacturers would spend extra money putting them on cars? I could go thru the heat transfer equations and demonstrate the theory, but it's too hard to get it too look nice in these forums. Stainless is a bit overkill. Polishing the insides would also decrease the radiation heat loss.
Re: ATP Turbine Housing heatshield Worth it? (kimosullivan)
theres also a bag style that looks like the sheet on the firewall
Discussion Starter · #7 ·
Re: ATP Turbine Housing heatshield Worth it? (SSj4G60)
Quote, originally posted by SSj4G60 »
Yes, I saw it at http://www.jegs.com but it cost more (US$91)
Now from these two heatshields, which one will be more efficient?
ive seenem for less just look around , the ATP one i think is just good for protecting surrounding wires and paint the one you posted would probably do a better job all around of keeping the heat in
Good god, that bag thing is fugly!
Why don't you cheap-ash punks ceramic coat your turbine housings and if that doesn't do it for ya you can go ahead and get the ATP stainless shield too (or be a real man and fab one up yourself).
Re: ATP Turbine Housing heatshield Worth it? (Angular)
will ceramic coats really do as much ??? live cc a downpipe vs. a wraped dp
The wrap will keep heat in more than ceramic coat. The wrap is more cost effective also.
Gary
I got my exhaust manifold and turbine housing ceramic coated for $215 Canadian including return shipping, tax, etc. It's not a bad price, and I got it coated with 2000ºF black satin ceramic coating.
The ceramic coating wasn't for the heat protection so much as it was to protect the manifold and housing from getting all rusted and crappy. I don't like rust
Here's a nice ceramic coat on a T76 turbo
http://personal.nbnet.nb.ca/ty...3.JPG
Discussion Starter · #13 ·
Re: ATP Turbine Housing heatshield Worth it? (StevenT)
Ceramic coat looks great but I'm not to worried about the rust and looks. My concern is that my engine is an counter flow, so my intake manifold is on top of the exhaust manifold. The hotside of the turbo will be just below from the air intake and TB.
I looking for a solution to avoid the heat radiation from the T3 to affect my cold air.
Cermachrome the intake too!!
I'm sure the bag and wrap stuff works great but it's just so damn ugly I would only use it as a last resort.
The stainless heat shield is nifty but might not fit in tight spaces. And does anbody know if it fits on turbos with internal wastegates?
Discussion Starter · #15 ·
Quote, originally posted by Angular »
Don't care, won't be able to see it since it's going to be in a Counter Flow engine.
Didn't though about that and I have an integrated wastegate....
I'll call ATP to find out
Thanks http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
NO! that heatshield is crap
I had one and it fell apart in a cuple of weeks. the braket fell off the shield
Re: ATP Turbine Housing heatshield Worth it? (vwnutter)
Anybody else have experience with the ATP heatshield? I'm getting alot of heatsoak in traffic and need some ideas.
Re: ATP Turbine Housing heatshield Worth it? (avw4me)
i would think that the "bag" type would supress too much heat... if you want to protect sensitive wires and such, wrap the wires with something protective and throw a wrx scoop above the turbo...
Re: ATP Turbine Housing heatshield Worth it? (AAdontworkx3)
afaik , keeping the heat in there better will also help to get the turbo to spool faster , it aids in scavenging , (not totally sure)
1 - 19 of 19 Posts
