Oil Pump Bolt Failure @ 59k
Add me to the list. If you are really interested, I posted details about the ensuing nightmare of service from the dealership on PassatWorld, but I'll give some tech info here:
Day 1 - 59k (and 5k left on CPO) 2006 3.6 4motion - engine light goes on during wife's AM commute (~62 mile RT), appointment made, EPC light comes on during PM commute.
Day 2 - car driven in EPC limp mode to dealer, wife gets rental.
Two weeks in, the engine is “done” but waiting for a seal. Three weeks in, and the engine is back together but there is another noise being investigated.
Day 33 (yes - thirty-three - not a typo) - car has had just about everything on the back side of the engine replaced, culprit was a backed-out oil pump bolt. The repair order shows $4253 total - $2179 in parts, $1249 in labor, and $825 in rental fees (presumably all at full retail and book rate). Dealer's customer backs into and destroys my door, but leaves insurance info.
Repair order and Invoice info (combined into one doc by me):
Text from invoice and RO combined:
A CUSTOMER STATES CHECK ENGINE LIGHT IS ON-CHECK AND ADVISE
CAUSE: ENGINE NOISE
15331971 CHAIN HOUSING COVER REMOVE+REINSTALL
1431 WV
1 03H-115-105-F OIL PUMP
1 03H-115-251 PIPE
1 WHT-002-780 SEAL
1 03H-109-503 CHAIN
1 03H-109-509-A TENSIONER
2 N-911-180-01 BOLT
1 066-109-570 SPROCKET
1 N-104-044-04 SCREW
1 03H-103-483-C GASKET
2 D-176-501-A1 SEALANT
1 03H-103-173 FLANGE
4 N-903-658-01 BOLT
3 03H-198-149 GASKET SET
3 03H-198-149-A GASKET SET
1 03H-133-237-B GASKET
1 021-103-051-C SEAL
1 06B-103-221-G VENTHOSE
2 N-907-399-01 CLIP
1 D-176-404-A2 SEALANT
1 071-115-562-C FILTERELEM
1 G-012-A8G-1G COOLANT AD
1 SYN CASTROL5W40 SYNTEC
1 N-908-132-02 SCREW
1 N-102-048-08 BOLT
1 03H-109-087-A ADJUSTER
1 03H-109-088-D ADJUSTER
1 03H-109-569 SPROCKET
1 03H-109-465 CHAIN
2 N-911-180-01 BOLT
1 D-174-003-A2 SEALANT
3 G-055-025-A2 ATF OIL
15331971 CHAIN HOUSING COVER REMOVE+REINSTALL PTS$ 2149.40 LBR$ 188.48
15351971 TIMING CHAIN REMOVE+REINSTALL 69.44
17201971 OIL PUMP REMOVE+REINSTALL 29.76
15841971 CAMSHAFT ADJUSTER REMOVE+REINSTALL 128.96
24471991 INTAKE MANIFOLD REMOVE+REINSTALL 218.24
50380950 LOCK CARRIER LOOSEN+FASTEN 49.60
63291900 FRONT BUMPER COVER REMOVE+REINSTALL 59.52
94151600 HEADLIGHT ASSEMBLY ADJUST 19.84
37351900 AUTOMATIC TRANSMISSION REMOVE+REINSTALL 386.88
17305521 OIL FILTER REPLACE 69.44
24402072 INJECTOR REMOVE+REINSTALL 49.60
01210004 TEST DRIVE 9.92
FC: 158410 EH7
PART#: 03H-109-509-A
COUNT:
CLAIM TYPE: G10
AUTH CODE: 15841
B MULTIPOINT INSPECTION
MP MULTIPOINT INSPECTION
PARTS 2149.40
LABOR 1279.68
TOTAL 3429.08
RENTAL 825.00 (33 days - not including body shop)
Total 4254.08
