OK, so I posted that I thought my transfer pump went bad. Here's what happened.
Pulled into Walmart and was idling and the car turned off. Restarting it took a few extra spins but she fired up. I drove around the lot and parked her. After a store run I came out, started her up (took a couple more spins than usual) and started to pull away. Just then she sputtered and died. I couldn't restart her. I was low on gas. Probably about 1-2 gallons left in the tank. My gauge reads off slightly so I knew I wasn't out. Anyway, I put in a couple of gallons and tried to start her. After a while she did crank and was idling but as soon as I pressed the throttle she died. Wouldn't start back up after that.
Towed her home last night. Went out to do some test this morning and here's what happened.
I took the rear access panel off to see the transfer pump assembly in the tank. I had a friend start the car and I listened. Couldn't tell if both pumps were going or just the main. It sounded like both were working even after unplugging the transfer. Next up was to remove the relay and jump it to try and hear. I had to have my friend listen and he couldn't tell if only one or both were running. After doing this for a few times I put the relay back in and cranked the car. She fired up after a few spins and ran PERFECTLY! It's like nothing was wrong. OK, so I named my car Mystery originally. That name is back. Any ideas? Have you had a sporadic transfer pump before? Should I just buy the relay and the transfer pump and swap them out?
One other thing, do you guys order a NEW o-ring when you do the job? Bentley says change it!
Any ideas?
And because no thread is worth looking at without pictures, here's a sneak peek of my new JUNGLE FOX photo shoot!
Any ideas?
