1 - 6 of 6 Posts
On my fathers 200, 3 out of the 4 windows stopped working. The manual says that there is a circuit breaker that will "reset" itself after over load. The rear windows never worked, and now the front passinger window does not work. The switchesl do not light up, as if they are not getting power. We don't have a Bentley, so I was wondering if someone here might know where to look for the circuit breakers. Is this a common thing for these cars? Any info on this problem would be apreciated.
Thanks!
-Andy
Re: Audi 200 power window question (Montanagreenmachine)
I've had several Audi's and they've had broken wire issues like this several times. Pop that boot back in the driver's side door frame and check out which wires are broken and solder and tape them back together.
Chris
One set of fuses/relays is on the driver's side behind the firewall, and the auxillary fuses/relays are under the dash..You need to undo a few bolts to get in there
1 - 6 of 6 Posts
