Well.... Time for a bump again..
So few months back I got the no spark issue fixed but the car was always a tad too loud, so I couldnt drive it on the road. This week I decided to take it to an exhaust shop to get it fixed, needs new silencer, and final silencer too, and a fix near the cat..
I always noticed the car was very slow IMO ( maybe its just the difference between my tuned car and this) but like something was not right. These days when I drove on overrun/off throttle it was banging like crazy, backfiring constantly like a rally car with ALS, and I ignored it tried not stay off throttle much.
Well anyways, when I went to get the parts for the exhaust , drove like 100m from shop , and I felt the car not going/lost power for like 3 seconds, I tried flooring it and I let off the throttle, oh boi what a choice that was... It backfired massively like an arty cannon, blew up the rear silencer , popped off rear bumper on left side, ofcourse I got pretty scared thought I threw a rod or something but it was so bloody loud. Thankfully it still started but couldnt drive it ofcourse with open exhaust.
So I had to leave the car there( I was planning to anyway since they only fix it up on monday), but there is still some gremlims with this car:
1. It has no lambda sensor atm - would be useless anyway, got a leak right at the flange which is getting fixed, but since there is no lambda, the car runs richer in safe mode ofcourse, but regardless it shouldnt be constantly popping on overrun like a rally car, that is only possible if the car is still injecting fuel when im off throttle which I am not sure why it does- unless the TPS switch is broken and doesnt know its on closed throttle, regardless why did it loose power/cut spark...
2. Instrument cluster does not do anything, but it was working literally 2 days ago, after 1 start it just decided to not work, still got illumination and blinker function on it tho, just no gauges at all. Probably a blown fuse(nr 15 if i remember right) but that does not happen without a short. Another thing like I mentioned before the oil light was still constantly on, which is probably caused by the picture in my last post in this thread above^.
3.When I turn igniton on the wipers do a wipe even when the switch is in normal position, this stopped after the instrument cluster stopped working
4.Hard start when engine hot - takes like 5-10 seconds of cranking to start the car when the engine is hot...
Coupling 2 and 3 together I am still fairly sure there is a short, linking back to original thread ... Also I dont know if it caused the power loss , probably like a spark cut which led to the explosion , since the injectors work regardless if the spark is there on Digifant. There is nothing but issues with this car, all I want it to be is a backup car to drive 6km / day half decently, so I can continue on my B5 (yes still couldnt do anything)
Appreciate any comment, thanks.
