I recently picked up a 2003 Audi A6 3.0 with approximately 120,000 miles. Today while driving it the check engine light started flashing so I pulled over shut it off, then started it again and it was fine. This same thing happened one other time. I scanned it with my vagcom and came up with some codes, but I'm not sure what particular code would be the cause of the flashing CEL. It seems as though the converters are prone to failure but I'm not sure if I should remove it or not. I also saw that there were misfires so I'm not sure if thats the cause of the flashing CEL. Any help would be much appreciated!
Tuesday,10,November,2015,15:37:08:17965
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WAULT64B73N054211 License Plate:
Mileage: Repair Order: AudiA6
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016752
Shop #: WSC 02325 785 00200
VCID: 377DEBD6450BA986AC-515C
6 Faults Found:
16805 - Warm Up Catalyst; Bank 1
P0421 - 001 - Efficiency Below Threshold - MIL ON -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16690 - Cylinder 6
P0306 - 001 - Misfire Detected
16689 - Cylinder 5
P0305 - 001 - Misfire Detected
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow
16688 - Cylinder 4
P0304 - 001 - Misfire Detected
Readiness: 0000 1000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 FF
Component: AG5 01V 3.0l5V USA 0910
Coding: 0001002
VCID: 70EF10CA60E53EBEAD-515C
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 R
Component: ABS/ESP allrad 2330
Coding: 06497
Shop #: WSC 01234
VCID: 306FD0CAF0657EBEED-5122
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00110
Shop #: WSC 02325
VCID: 65C1719EFF27EB16CE-257E
4 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 Q
Component: Airbag 8.4EP 2001
Coding: 0000607
VCID: 3E73FEF26A3198CE6F-5140
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
VCID: 2F6DD3B6ED5B6146F4-5140
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 EX
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 02262
Shop #: WSC 08701
VCID: 020B4A020E493C2E4B-5140
WAULT64B73N054211 AUZ7Z0B2251642
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D37
Coding: 15885
Shop #: WSC 02325
VCID: 3365DFC6017345A690-4F02
4 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
01562 - Rear right door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
VCID: 2C57C4BADC4D1A5ED1-4AFE
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 02325
VCID: 04074C1A145D321E79-4B16
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 L
Component: symphony II NP2 0051
Coding: 00205
Shop #: WSC 40201
VCID: 29593DAED3BF0F762A-4EB0
End-------------------------(Elapsed Time: 05:15)--------------------------
www.Ross-Tech.com
75 76 77
Coding: 0016752
6 Faults Found:
P0300 - 001 -
16690 - Cylinder 6
16689 - Cylinder 5
16688 - Cylinder 4
Coding: 0001002
Coding: 06497
Shop #: WSC 01234
Coding: 00110
Shop #: WSC 02325
4 Faults Found:
Coding: 0000607
Coding: 01002
Shop #: WSC 02325
Coding: 02262
Shop #: WSC 08701
Coding: 15885
Shop #: WSC 02325
4 Faults Found:
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00050
Shop #: WSC 02325
Coding: 00205
Shop #: WSC 40201
