1 - 20 of 22 Posts
does anyone know if the rims on the A8 will fit on a 2001 jetta. i want the rims that are solid with tiny holes in the top near the tire. they are brushed aluminum. they are so hot. post pics if youve done this.
thanks Austin
Re: Audi A8 rims on an MK4 jetta (austieB2.ohhh)
sorry, i originally posted about S8 wheels. if you have specs on the A8L wheels, post them here, and i'll tell you if they may fit or not.
[Modified by cadiburns, 5:50 PM 2-6-2002]
I guess with adapters this can be done, as the offset is 45mm. Add about 25mm to that and that will give you ET20, which can fit under your car, with the right tires. No one here has this. The lug pattern is 5 X 112mm
My Eurovan has S8 wheels on here, they are the earlier models but Audi S8's none the less
Otherwise you can do the S3 wheels for the same look, they are just not 18" they are 17"
Re: Audi A8 rims on an MK4 jetta (brownie)
those aren't the wheels he is talking about. those are the S8 wheels you got. the wheels he is talking about are the A8L wheels. basically looks like a serving tray with holes around the outer edge. out of curiosity brownie, what are putting those wheels on?
Re: Audi A8 rims on an MK4 jetta (cadiburns)
hopefuly a black gti in the spring.
if not, my silver golf 1.8t
ooh, i checked the bolt pattern in case you were wondering too
these are replicas so they are similar to s3 wheels
[Modified by brownie, 9:49 PM 2-6-2002]
quote:[HR][/HR]i dont know if this is what you are looking for...
http://gbrown.dhs.org/wheels/
i just bought these[HR][/HR]​
Nice, that is what I originally wanted for the EV, but couldn't find a set at a reasonable price in time. http://****************.com/smile/emthup.gif
those wheels are 5x112 eith an ET of something like 45 (as per Roger). I think you can get spacers that are between 15-20mm, so they won't be THAT bad, but will poke out. they will also look insane with a fender pull tucking!
Re: Audi A8 rims on an MK4 jetta (Roger Moore)
[HR][/HR]​
hey, that's cool http://****************.com/smile/emthup.gif
1 - 20 of 22 Posts
