1 - 2 of 2 Posts
V6 ceased outside motor plan so swamped it for a Chevy LS1 5.7V8 onto the CVT Quattro Transmission...
All is well except for 1 thing...
The CVT Transmission wants to see RPM on the cluster to engage gears...
I fitted the Crank pickup and Sensor to the V8.
The problem is it jumps very erratically...
Goes in gear and out in 3 sec.
Is there anyone that can give me advise or solution?
Check the mounting of the CPS sensor pickup & reluctor . The mount should be very solid and stiff. Also, there may be a specified min/max clearance and alignment between the pickup & reluctor. If someone has an oscillocope they can check the waveform.
https://www.samarins.com/glossary/crank_sensor.html
1 - 2 of 2 Posts
