did anyone else confirm this is working ?hello my friends ,i have a mk2 tt 3.2 2007 model.dsg, mag ride. my sunspension died a long time ago(now i hav 220.000km) and i dont have the buget to get a NEW set.didn want to go coilover with the delete kit.. i bought some Cheap monroe oem style shocks and i have a nice soft ride for an every day Car. so i was searchinfg the globe to see if i can delete the fault codes and de-code complitly the mr like it was never installed..no such thread,so i gathered as many clues i could and start with my vcds with simple order. STEP1: remove the fuse 9 from the fuse BOX drivers side. STEP 2: open vcds -CAN GATEWAY-INSTALATION LIST- un-click mag ride. STEP3:VCDS-INSTRUMENTS CLUSTER-CODING-change the value according to the bubble and equipment.Character 4(Value 64 = Magnetic Ride chassis).remove 64 from the coding!.. STEP 4:vcds headlight range control --change coding to 0000010 = Headlight range control automatic/dynamic + four-wheel drive + steel springs (PR number 8Q3 + 1X1 + 1BA/1BV)(0000009 for front Wheel Car).. STEP 5:vcds-ABS module.this is the one...no buble for help in coding.i had coding 0026177.(quattro+mag ride+dsg+v6 engine+340mm brakes).. test many possible codes.but THIS work for me:0017985.. no faults codes,no rewiring,no modules unpluging,no esp problems(not disangaging)..like never had mag ride. GOOD LUCK!!
thanks
