41 - 47 of 47 Posts
My TTS has 104,000 km, and my rear MR shocks are dead. One is totally destroyed.
I want to switch to a threaded handset. In this but I am interested in the programming of the vagcom. that I have a very large part settled, I still have a problem with headlights.
Let me explain :
STEP 1: I have removed fuse 9 (Magnetic ride)
STEP 2: With the VCDS - 17-7 (Instrumentation).
I changed the value of the cararctere (Value 64 = Magnetic Ride chassis).
In my case 0065428 replaced by 0001428.
STEP 3: VCDS - 3-7 (Brake)
In my case 0616246, from which we must subtract 8192, or 0608054.
At this stage, no worry of suspension.
No more worries, ABS, ESP (which one can be connected, disconnected).
STEP4: VCDS - 55-7 (Xenon)
Modification of car signage
In my case 0000011 replaced by 000000010 four-wheel drive + steel springs.
There, it removes my headlight code but the error code comes back. Does someone have an idea ?
I know there are K&W keys, but I want everything to be in software mode. Especially since there is a lot of concern of failure of these products.
Thanks in advance.
Premium Member
2013 Audi TT RS
I've tried every combination and the only options through coding are as follows:
  • Get rid of the suspension warning light but not have the ability to turn off the ESP.. I went with this option as I rarely have the need to disable it
  • Get rid of the suspension warning light but introduce the headlight error, and maintain control over ESP.. I use this for track time and revert after.. I can't stand warning lights.
Hi,
I am like you. I cannot support error on my board. That's why i asked and moreover i make track one time per month.
I will use a lot my vcds.
Thanks a lot. for your help.
hello my friends ,i have a mk2 tt 3.2 2007 model.dsg, mag ride. my sunspension died a long time ago(now i hav 220.000km) and i dont have the buget to get a NEW set.didn want to go coilover with the delete kit.. i bought some Cheap monroe oem style shocks and i have a nice soft ride for an every day Car. so i was searchinfg the globe to see if i can delete the fault codes and de-code complitly the mr like it was never installed..no such thread,so i gathered as many clues i could and start with my vcds with simple order. STEP1: remove the fuse 9 from the fuse BOX drivers side. STEP 2: open vcds -CAN GATEWAY-INSTALATION LIST- un-click mag ride. STEP3:VCDS-INSTRUMENTS CLUSTER-CODING-change the value according to the bubble and equipment.Character 4(Value 64 = Magnetic Ride chassis).remove 64 from the coding!.. STEP 4:vcds headlight range control --change coding to 0000010 = Headlight range control automatic/dynamic + four-wheel drive + steel springs (PR number 8Q3 + 1X1 + 1BA/1BV)(0000009 for front Wheel Car).. STEP 5:vcds-ABS module.this is the one...no buble for help in coding.i had coding 0026177.(quattro+mag ride+dsg+v6 engine+340mm brakes).. test many possible codes.but THIS work for me:0017985.. no faults codes,no rewiring,no modules unpluging,no esp problems(not disangaging)..like never had mag ride. GOOD LUCK!!
I have a question related to this. I replaced all 4 of my magnetic ride struts on my 09' B8 A4 SLine and it seems to be on the firm ride and when I switch to comfort I still get the same ride.
Is there a reset I need to do to get the struts to come out of stiff ride into comfort?
Will this work on 2021 RS6?
1. With stock ride height sensors plugged in. Along with kw esc delete. Errors are mag and diff.
2. With a shock sensor delete plugged in. Along with kw esc delete. Errors are mag and headlights. (*delete built by SDE)
Goes in limp mode. 30mph max
Tire Wheel Car Vehicle Vehicle registration plate
Wheel Tire Vehicle Car Automotive lighting
Tire Vehicle registration plate Automotive tail & brake light Wheel Vehicle
41 - 47 of 47 Posts
