1 - 12 of 12 Posts
Moderator
I had this link in my favorites and I thought it should be on here so it can be searchable...
Bentley Publishers has an online technical library for Audis, with a service interval checklist, Fault Code List, and links to the Audi Technical Discussion Board. Lots of good info.
http://www.bentleypublishers.com/tech/audi/
Direct link to Service Intervals for b5's-
1997: http://www.bentleypublishers.c...d.pdf
1998: http://www.bentleypublishers.c...d.pdf
1999: http://www.bentleypublishers.c...d.pdf
2000: http://www.bentleypublishers.c...d.pdf
2001: http://www.bentleypublishers.c...d.pdf
Direct Link to DTCs:
http://www.bentleypublishers.c...e.htm
If we're still doing the FAQ thing (it's been a while, hasn't it?) maybe this would be helpful to get in there.
Moderator
Discussion Starter · #4 ·
Re: Audi Online Technical Library (TurboNasty)
Dude I always need DTCs <g>
Re: (Greyhound Guy)
Timing belt at 90K!?!? You might be a little crazy if you wait that long.
Edit: what, what?? 105K on the 2000? If you follow that schedule you might need to add an %80 line factor. There is an %80 chance that you'll be replacing the top end of you ENGINE at 65-75K.
Modified by A4_For_Baby at 9:57 AM 10-14-2005
Moderator
Discussion Starter · #7 ·
Re: (A4_For_Baby)
Bump... this should get added to the FAQ, even if I do say so myself. Can a few of your guys ask the mods to get it in there? I PM'd peter already, but some more support would be good. We need to get the FAQ beefed up a little more.
Thats what I am saying. However it does make me feel better that the lengthened the time interval due to the newer tensioner. So maybe our cars are more like 90 instead of 70. Doesn't matter, i did mine with some buddies at 50K when I had the front off.
Re: (Greyhound Guy)
im just got my use d 2.8 a4, 01, 38K+miles from the dealer today. so is it the enthusiasts collective opinion that the maintenance intervals suggested by audi isn't really good?
thanks!
im a newb!
Re: (dstdub)
Quote, originally posted by dstdub »
i wouldnt say isnt good..but the stuff like timing belt i would do about 10k before it says to do it..you should be alright on everythign else..
1 - 12 of 12 Posts
