1 - 2 of 2 Posts
Hello
I change the timing belt of an AVK engine i use the tools that AUDI design for this engine and lock the crankshaft ,lock the 4 cams ,and the engine still have misfire in the cyl 1 and 3 i intaerchange the coils and nothing happend ,i check almost 3 times the timing whit the tools and the problem persists ,anybody work whit this engine ?
Santos
Re: Audi V6 engine problem (santos_performance)
the engines are known for bad coils, but look at the camshaft gears, I have seen the bolts back out on some of them. Swap the coils around and/or the spark plugs and see if they move. Other then that I haven't seen many problems with misfires so far.
Hope it helps
1 - 2 of 2 Posts
