audio newbie question
528 Views 3 Replies 3 Participants Last post by  waka
Just about done with bolt-on mods, and wanted to do an in-dash change. Are there any in-dash cd players that will be a direct replacement for the oem HU (with monsoon) that will be "plug-n-play"?
Thanks
See less See more
1 - 4 of 4 Posts
Re: audio newbie question (waka)
as plug in play. most decks will be after you put together the little harness (basicly lets you plug in a say.. sony deck into the stock wiring). These usually run 10-20bux and you just solder or use quick connects to connect the wires together (basicly color matching, any shop can do this for you for a lil $$) then just pull out old deck, pop in trim ring, and new deck slides in.
ya might also wanna think about a disc changer..and running that off your OEm headunit. that way your deck will match your interior perfectly..and you won't have a useless deck laying around eh?
Thanks for your help guys...decided to go with the changer in trunk route. http://****************.com/smile/emthup.gif
See less See more
1 - 4 of 4 Posts
