so my wife goes and fills up the car with gas. she turns the car on and see's the check engine light on. so we drive back home and connect the ol vag and this is what comes out. not really worried cuz its under warranty. but is it safe to drive??? dont really feel like driving the gli today.
notes: all stock minus radio. 2009 VW Jetta SE 2.5l
VCDS Version: Release 908.2
Data version: 20100326
Sunday,20,June,2010,12:54:44:32661
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K69M004129 Mileage: 21630km/13440miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
Address 01: Engine (CBU) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 055 M HW: 07K 906 055 M
Component: 2,5l R5/4V G 3253
Revision: G6H01--- Serial number: VWX7Z0H524L1L5
Coding: 0000075
Shop #: WSC 00066 000 00000
1 Fault Found:
005386 - Engine Off Timer Performance
P150A - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 130 /min
Load: 71.3 %
Speed: 255.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.160 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
No fault code found.
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B400D492200FE880C02E6922200413000
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000967616
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
Part No: 1K1 955 119 E
Component: Wischer 190608 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0347448
Coding: 0000100
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 18
Reset counter: 172
Mileage: 20420 km
Time Indication: 0
Date: 2000.00.00
Time: 16:52:41
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M05N7XO
Coding: 0013889
Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H524L1L5
Coding: 0023203
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 100508F2000981
Coding: ED807F070003021002
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 628 km
Time Indication: 0
Date: 2000.00.00
Time: 18:43:29
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 1222
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000788888616
Coding: 0001205
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186083F2904058FB0880F0488DCA0
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000857588618
Coding: 0001204
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000003189046
Coding: 0001168
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
Shop #: WSC 22580 444 54008
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000003194024
Coding: 0001168
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0000075
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 130 /min
Load: 71.3 %
Speed: 255.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 10.160 V
Coding: 0000840
Revision: 00H35001
Coding: 00038805
Shop #: WSC 00066
Coding: 0000100
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 18
Reset counter: 172
Mileage: 20420 km
Time Indication: 0
Date: 2000.00.00
Time: 16:52:41
Coding: 0013889
Coding: 0010021
5 Faults Found:
00576 - Terminal 15
Coding: 0023203
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 628 km
Time Indication: 0
Date: 2000.00.00
Time: 18:43:29
Coding: 0001205
Revision: 00H15000
Coding: 0001204
Address 56: Radio
Cannot be reached
Coding: 0001168
Component: RDK 0450
Coding: 0100101
Coding: 0001168
