Re: Auto Tranny filter & fluid change?? (88GLI97B4wagon)
The B4 passat automatics had an electronically adaptable transmission that tries to figure out how you drive and shift accordingly. You can try resetting the electronic memory on the transmission. To do so.
- turn the car on, but don't start it
- press the gas pedal the way to the floor
- hold for a count of 12 then release
- turn the ignition off, then back on. It should shift much more readily and can be reset again at any time.
Try that first, because I don't think the tranny needs to be flushed till about 60,000 miles.
