Quote, originally posted by ed j » |
Need help. I purchase the Autotech fuel pump kit and had it installed by my mechanic, who is highly qualify. He ran into an issue with the pump being seized. This is what he wrote to me: "Hi Ed, concerning your autotech fuel pump upgrade, I installed yesterday, and today I took it for a test drive, and the car went into limp mode so I pulled in the garage and pulled off the pump again, checked the piston, and it was seized into the pump. I took it apart again, recleaned it, polished it, and put it back. It appeared to be working fine off the car, not seized and moving in and out smoothly. I reinstalled it in the car and went for a drive. It was fine until I floored it, then it went to limp mode again. I pulled off the pump AGAIN, and noticed that the piston was fully compressed and seized again. I put back your oem piston and sleeve, and the car runs perfectly again. Upon further inspection of the autotech piston and sleeve, I noticed scarring of the piston and the bore of the sleeve." |
Trust me buddy. I'm in a jam and have contacted Autotech as well. I'm not here to ripped anyone. Also, I know someone else that has a seized pump issue as well. But he didn't want to post it. I hope he does jump in and say something. I'm just trying to solve this issue so that other who do run into the same problem can benefit. Modified by ed j at 5:27 PM 10-25-2007 Modified by ed j at 5:28 PM 10-25-2007 |
Quote, originally posted by GolfRS » |
You are aware of course this post is gonna turn ugly VERY SOON..... ![]() Modified by GolfRS at 12:34 AM 10-26-2007 |
Quote, originally posted by BIGNICKSGTIS420 » |
That depends on you
I did get a reply and a replacement part will be sent out. Will keep everyone posted. |
