1 - 5 of 5 Posts
So today my Autotech Q chip came in, and I was going to put it in when.....the wiring harness on my ecu will not budge. I pulled and wiggled as much as I could, but still nothing at all. I pulled on where the wires go in, on the black thing along the side of the actual ECU. If there are any tips on what to do, or anyone that had the same experience, please tell me what you did. For the time being, I put everything together and the car is running fine, but I would like to get the chip in this week. Thanks alot in advance. -Chris
Re: Autotech install emergency!!! HELP!! (SilverDub92)
put your left hand on the opening of ecu, while standing on passanger side of vw... there is a clip by tour index finger ... just unlatch it and the harness will so ever looson and disconnect... dont force or pry it comes off with no force after you unlatch clip by firewall..
Re: Autotech install emergency!!! HELP!! (taylor976)
Do I do this while the actual ECU is still bolted into place near the firewall? Thanks so much.
1 - 5 of 5 Posts
