http://www.autoweek.com/apps/p.../1009
The review is generally very positive but at one point they say that the motor, when pushed, emits a "remote and not especially pleasing (to our taste) metallic, insectile note."
Quote » |
Emperor Joseph’s problem was that he knew how to read music. “Your work is ingenious,” he informs Mozart in Amadeus. “But there are too many notes. Just cut a few and it will be perfect.” To which Mozart famously retorts, “Which few did you have in mind, Majesty?” Satoru Maruyamano must relate to that. Maruyamano-san is so enthusiastic about European classical music that after a good European dinner he cannot resist leaping up to conduct the violinists. But in his day job for nearly the past five years he has been chief engineer of the Lexus LS 460, a new corporate flagship crammed to its side curtains with so much technology that an early draft of the owner’s manual ran more than 700 pages. Lexus officials admit to just a bit of concern about that. (“We do gain sales from not having iDrive,” remarks one dryly.) The last thing they want is for their clientele to fret about managing what has to be the most complex machine this company has ever offered. But what to cut from the book? It’s all such keen stuff, and so much of it requires explanation. Like the optional, hands-off self-parking system, the first in a production vehicle. We find it works well, but it takes some learning. Luckily one can enjoy music without reading the score, and Maruyamano’s orchestra of 1500 has so harmoniously integrated the 460’s gadgetry that owners needn’t give a thought to most of it. They won’t have to know this fourth-generation LS is the first completely fresh design in the model’s 17 years, and that it feels faster because of a larger, higher-revving engine; that the transmission is the industry’s first eight-speed, benefiting both performance and economy; that the steering—now electric—features twin-axis kingpin geometry like Audi’s, for sharper response; or that Toyota Formula One racing experience is manifest in a “stepped venturi” panel under the engine, which reduces lift. Drivers even can enjoy the super-smooth texture of the steering wheel without knowing the leather was buffed for three hours, six times longer than before. In fact, during introductory drives in Austria recently we found it possible to cover some considerable kilometers in the LS 460 without noticing much difference from the outgoing 430. It is a whole new car, but it’s still that much of a Lexus. The overall dimensions are very similar. The ambience is fully familiar. The feel, the manners, the quiet are all just what LS owners love. Except there’s more of it all. More gizmos and features and luxury appointments, yes, but kick up your driving tempo and the 460 comes more alive, more eager, brighter. That’s not to say it’s the kind of hard-core sports sedan that incites misbehavior, but the initial experience suggests some who trade out of a 430 might more often find themselves muttering, “Oops, I’m speeding.” They might be ones who shouldn’t hear this: For the first time Lexus allows the traction/stability control to be turned off. Completely. Tap the button once and the system stays off until the speedometer reads 30 mph; that’s for “rocking” out of snow. But hold the same button down longer than three seconds and you can spin your little wheels as fast as they will go (up to the governed 130 mph). “Just be careful,” commented a corporate officer. A refreshing attitude in this industry today. All this added liveliness is deliberately expressive of the fact Lexus is now organizationally separate from Toyota and going its own way in terms of design, engineering and manufacturing. The outgoing car was staid-looking, but the “L-finesse” corporate styling theme has now been applied to the 460 in an edgy way that adds visual energy. The conceptual source of these lines is the two-seat LF-A coupe that toured the auto shows last year, and Lexus personnel confirm they will be producing just such a supercar one day not soon enough. That should give the new 4.6-liter engine a real ride. In the LS 460 it’s hidden under a gormless slab of plastic, and that’s a pity, because it’s a beauty. While not many LS sedan intenders are likely to be moved by learning of its connection with Toyota’s Formula One racer, the chief engineer vows it is real. In Maruyamano’s words through an interpreter, the new V8 was “spun off together” with the F1 program. Not that they share components, but they are expressions of the same knowledge base. Thus this first new V8 design since 1989’s LS 400 has precisely the optimal bore diameter (94.0 mm) to yield the least possible friction as the aluminum block distorts during temperature and stress cycles, he says. “That was the first decision.” Other ultra-high-performance thinking can be found in many areas of this street motor. Like a racer, it has roller cam followers for lower friction, sharper profiles and higher rpm. To the same ends the cams are manufactured with a new process: Each of the 32 lobes is forged and ground individually, then locked precisely into place on the four shafts—which are hollow like rifle barrels to save weight. (No, that’s not a secret from the F1 shop, according to Lexus technical trainer Bob Allan: “They don’t need the engine life.”) In another first, cam timing is adjusted electrically rather than by the former hydraulic system to avoid temperature-induced variations. Listen to this—they force a liquid abrasive through the crankshaft’s oil passageways to make them slick, reducing resistance to flow. “Oil-smoothing,” they call it. These and many other tricks add up to a honey of a V8 that is 7.3 percent larger than the old 4294-cc unit yet makes a whopping 36.7 percent more power. The numbers are 4608 cc, 380 hp at 6400 rpm (102 hp and 800 revs higher than before despite a slightly longer stroke) and 367 lb-ft at 4100 rpm (32 percent more torque peaking 700 rpm higher). Yet it’s claimed to be class-leading in fuel efficiency. In the company’s words, the new 4.6 offers the power of a 5.5 with the economy of a 3.5. In the words of Maruyamano, “Other companies intend from the outset to apply supercharging to get performance. We prefer to do it from basic design.” He is very proud of this engine. Enthusiast LS drivers will want to keep all this in mind about the engine, because they won’t hear much from it. It’s so quiet in normal driving that aural cues can’t be used for manual-mode gearshift decisions. Only when whipped does it emit a remote and not especially pleasing (to our taste) metallic, insectile note. Hopefully the LF-A super coupe will really scream, both literally and figuratively. Regarding that eight-speed, the chief engineer says the rationale is that more gears allow both a lower low and a higher high, while also keeping the engine in its sweet zone more of the time. Why not just go to the CVT that will be in the forthcoming hybrid version of this car? “It has torque limitations,” he admits. But the hybrid 600h will have all-wheel drive, and snow country folks will be glad to hear awd is to become available in the LS 460 as well. Enough boring technoid talk; what about the fun stuff? Okay, there’s a throne. Order the new-to-Lexus long-wheelbase edition, the 460 L, and its extra 4.72 inches make room for an optional right-rear executive-class recliner with extending ottoman leg-rest, shiatsu massaging seatback and “the world’s first” motorized nine-inch DVD screen that deploys from the overhead. Truly fit for an emperor. One of them at a time, anyway—the driver’s seat prevents a second rear ottoman. Even more amusing is the Advanced Parking Guidance System. When so equipped the car will parallel-park itself either to the right or the left, and also back itself neatly into a slot too narrow for the doors to open. (Why you would want that is your affair.) Twelve sonar sensors take care of determining if there is enough room as the car approaches a likely place and stops in the usual fashion. When you select reverse, a green quadrangle representing the car’s perimeter appears on the dashboard rearview TV screen. By touching arrows on the display, move the virtual car into the open space. If the computer thinks there is a danger of hitting something, the obstruction will be indicated in red. In that case you must either adjust the quadrangle or drive someplace else. Finally, keep your hands off the wheel but your foot on the brake and allow the LS to creep backward. The wheel cranks itself furiously, like an invisible drift driver is sitting in your lap, and the car maneuvers precisely into place, scratch-free. Except for an important, important note: It’s up to you to stop at the end of the process. The system won’t automatically apply the brakes. Can you think of cities where other motorists won’t grant you enough time to go through this exercise? Sure, but we predict self-parking will be a sellout. Speaking of which, the LS 460 goes on sale in October. Pricing is yet to be announced. There is so, so much more packed into this new LS; it’s a regular automotive Nozze di Figaro. But we wouldn’t cut a note. |
